z31maniac
z31maniac UberDork
6/5/12 7:37 p.m.
Trying to put the rear suspension back together, these Sport brakes are going on a '90.
How to do the clip/springs go back in? Anyone have pictures? (would also be nice if you had the fronts as well)
Currently searching the googles as we speak.
z31maniac
z31maniac UberDork
6/5/12 9:25 p.m.
Found this, seemed to help.
Now off to look for the front.
z31maniac
z31maniac UberDork
6/6/12 3:02 p.m.
Fronts the same? Not at home to check right now.
z31maniac
z31maniac UberDork
6/14/12 7:55 p.m.
Bump for which ports on the Sport master cylinder to the existing brake lines go to?
Keith
Keith GRM+ Memberand MegaDork
6/14/12 10:38 p.m.
Front ports to front brakes, IIRC. If it's a non-ABS cylinder, the front circuit is the one with two ports.
z31maniac
z31maniac UberDork
6/15/12 7:22 a.m.
Hmmm, I'll have to take a pic when I get home. THere are two ports on the "driver side" of the MC at the front and rear, and one port on the "passenger" side that's about in the middle between front and rear.
I bought it from you guys, if that helps at all.
Keith
6/15/12 11:40 a.m.
Sounds like an ABS master, there's going to be an undrilled boss on the top of the master at the front where the second front outlet goes on a non-ABS car. If that's the case and you don't have ABS, you'll need to put in a tee to split the front lines.
ABS Sport master cylinder:
z31maniac
z31maniac UberDork
6/15/12 12:15 p.m.
Whoops! We never brought that up! Just that I need a SPort master cylinder for installing Sport brakes on a '90.
Any idea what sizes I need to buy? That way I can grab the parts on the way home?
Keith
6/15/12 1:08 p.m.
You'll need a short piece of metric brake line that's been pre-flared with ends - 3/16" or 4mm, the smallest size. The tee will also need to be metric - you should be able to get one with three inverted flare fittings on it. Thread size is 6x1.0, but it's about the only size you'll find on cars.
wxNOTiHuRSPrA0ksq2CCdWLADroQFU3g7hVIVEShUD26BA1wqQcU76AzXgnXjI8T
