DeadSkunk
DeadSkunk Reader
1/29/10 3:12 p.m.
Does anyone know if the 5 speed transmission in MINIs are interchangeable with another make of car? Or, were the guts so, but not the housing? Just looking for a cheap way to fix a MINI with a bad transmission. I know it's a longshot.
John Brown
1/29/10 3:17 p.m.
I hope they are interchangeable with a Neon, just so I can build a 2.4L turbo MINI.
rob_lewis
rob_lewis GRM+ Memberand Dork
1/29/10 4:57 p.m.
I have not heard of one.
Several have swapped the S 6-speed in. It's not a cake walk, but can be done by "normal" humans. Swap PDF Linky here
Have you done any looking for a good used? Or do you not want to install a Midlands again? You could probably pick up a used for under a grand.
-Rob
DeadSkunk
DeadSkunk Reader
1/29/10 6:08 p.m.
I was just wondering because I found a Cooper for $3000, but the transmission is trashed. If a used tranny could be found for less than $1K, it would still be a good deal. Wasn't the first gen MINI engine developed with Chrysler in Brazil? Makes you wonder if a Neon unit might work, but it's pretty darned tight under the hood of any MINI, regular or S.
Ian F
Ian F Dork
1/29/10 7:31 p.m.
This subject has been discussed at length on the MINI forums.. Unfortunately, no.
The Tritec engine has nothing in common with any US-Chrysler product. The engine was supposed to have been used on some Euro-market Chrysler models, but it didn't work out quite as well as hoped.
Does your $3000 MINI have a busted manual or CVT? If it's a manual, that's a good price. CVT - not so much. An auto car can be converted, but it's a tedious and not-so-cheap process.
DeadSkunk
DeadSkunk Reader
1/29/10 8:08 p.m.
It's the 5-speed manual. I have been watching MINI prices for 3 years now, since I sold my SpecMiata . I've wondered how a MINI Cooper would do in ITB. When I spied a $3K Cooper the wheels started turning again
Ian F
Ian F Dork
1/29/10 9:10 p.m.
Not a bad price, then. If you go for it, look for a later Getrag rather than the earlier Midlands transmission.
I have no idea about its chances in ITB.
rob_lewis
1/29/10 9:41 p.m.
Can you swap transmissions in ITB? If so, I would put the 6 speed in it.
IIRC, the later Getrag 5 speed isn't as easy of a change as the 6 speed was, so most don't do it.
$3k is a pretty good price. You'll want to check on how "loaded" it is if you're racing. Most of the early MINI's had tons of options that would just be a pain to remove.
-Rob
drmike
drmike New Reader
1/29/10 11:54 p.m.
rob_lewis wrote: I have not heard of one. Several have swapped the S 6-speed in. It's not a cake walk, but can be done by "normal" humans. Swap PDF Linky here
This is from my company. I was going to post this, but you beat me to it!
WqOty8bcpC6E7MWbvugqvKEu0d01gu8WOYpeqDnOV3WJVpTdU3gmVVLm1d1PVnjl
