Woody
Woody GRM+ Memberand MegaDork
11/12/12 11:34 a.m.
Just in case I need to build a car for next year's Race of Gentlemen, I bought a cylinder head for a Hudson Terraplane. I don't own a Hudson Terraplane, of course, and in the event that I can even find the rest of an engine (along with the appropriate transmission), it wouldn't be going into a Terraplane anyway, because that would just be silly.
But it was rusty, having been found in an old barn. Or perhaps, near an old barn. Anyway, I decided to give it a dip in the electrolytic rust removal bucket.
Photobucket
Photobucket
I thought it turned out pretty well for something that required just time and almost no effort.
Photobucket
Photobucket
Even if it just becomes garage art, I think it's a pretty cool looking piece.
Duke PowerDork
11/12/12 11:38 a.m.
Can I put my entire '67 Pontiac in that?
Woody
11/12/12 11:39 a.m.
You'll need a bigger bucket.
Apexcarver
Apexcarver UberDork
11/12/12 11:42 a.m.
I am messing with an old motorcycle that I might try this for a good many parts.
Wonder if it would work at all on a tank... I have my doubts that it would really work on the inside... but maybe... would be awesome if it did!
RossD
RossD UberDork
11/12/12 11:51 a.m.
Use the tank as the bucket. Put the sacrificial part in through the filler and isolate it from the tank.
Curmudgeon
Curmudgeon MegaDork
11/12/12 11:54 a.m.
That's pretty cool. On some of the bike forums, there's guys who have done the inside of tanks by filling them with the solution, then sticking the negative electrode in through the fill neck and firing it up. You just have to be real sure the negative electrode doesn't touch the inside of the tank.
EDIT: Ross beat me to it.
Graefin10
Graefin10 Dork
11/12/12 12:02 p.m.
RossD wrote: Use the tank as the bucket. Put the scarificial part in through the filler and isolate it from the tank.
What kind of metal is the sacrificial electrode made of? How much baking soda do you use per gallon of water?
Woody
11/12/12 12:04 p.m.
Apexcarver wrote: I am messing with an old motorcycle that I might try this for a good many parts. Wonder if it would work at all on a tank... I have my doubts that it would really work on the inside... but maybe... would be awesome if it did!
You would need to get a sacrificial anode that would fit inside the tank without coming in contact with any other metal. Not impossible, just a little tricky.
I just use bare steel as an anode. Lots of people use rebar.
Woody
11/12/12 12:06 p.m.
I use about two cups of Washing Soda per five gallons.
I had to turn the battery charger up higher than usual for this one, probably since the cylinder head was so heavy. I usually use 12V 2amp but went up to 12V 6amp.
Woody
11/12/12 12:07 p.m.
The sacrificial metal needs a direct line of sight to the piece that you are trying to de-rust.
Raze
Raze SuperDork
11/12/12 12:14 p.m.
awesome
RossD
RossD UberDork
11/12/12 12:18 p.m.
You could use a bit of wood for the plug with a hole drilled in the middle for the piece of rebar.
44Dwarf
44Dwarf SuperDork
11/12/12 2:01 p.m.
I use a 30 gallon storage tub from the $ store. and what ever is in the scrap pile for the anodes. Cracked Ford flex plates work great.
44Dwarf
44Dwarf SuperDork
11/12/12 2:02 p.m.
http://antique-engines.com/electrol.asp
DeadSkunk
DeadSkunk Dork
11/12/12 3:18 p.m.
How would this work on a rusty/painted part like a Miata lower control arm?
Woody
11/12/12 3:31 p.m.
It will work on the rusty part, but not the painted part.
stan_d
stan_d Dork
11/12/12 3:40 p.m.
What do you do with the nasty stuff after?
nocones
nocones GRM+ Memberand Dork
11/12/12 3:45 p.m.
As my grandpa always said when pouring stuff out on his gravel drive..
The rocks know what to do with it...
dculberson
dculberson SuperDork
11/12/12 4:05 p.m.
Is it even nasty stuff? Seems like it would be iron oxide, baking soda, and water... what nasty stuff would end up in the water?
44Dwarf
44Dwarf SuperDork
11/12/12 5:40 p.m.
Pour it on any part of the lawn that has moss you wish to kill, then plant grass seed the next month. As for painted parts it will creep under to a point but will not strip the part.
erohslc
erohslc HalfDork
11/12/12 6:10 p.m.
For big stuff, score a cheap kiddies wimming pool (Craig's List, etc).
Lay down steel wire mesh, etc, attach the wire.
Lay down a couple of 1x2 etc to insulate, then the part, attach the other wire.
Cover with water/soda solution, hook up current source, and cook 'til done.
erohslc
erohslc HalfDork
11/12/12 6:18 p.m.
For a whole car:
1) Get a cheap above-ground pool
2) Lay down floor part of pool
3) Drive (or carry, with 4x4's and lot's of friends) car to center of floor.
4) Attach heavy wire to car
5) Arrange sacrifical steel pieces around car, connect with heavy wire.
6) Assemble pool walls around car.
7) Add water to cover
8) Add soda, use outborad motor to stir and dissolve.
9) Attach wires to welder, or other high current DC source.
10) Cook 'til done
BTW, if someone does this, pictures, or it didn't happen.
44Dwarf
44Dwarf SuperDork
11/12/12 7:22 p.m.
erohslc wrote: ;) BTW, if someone does this, pictures, or it didn't happen.
http://antique-engines.com/trailer-electrolysis.htm
pictures of a large trailer.
Hal
Hal Dork
11/12/12 7:47 p.m.
Good job, Woody. Now all you need is a few more pieces to build one of these.
erohslc
erohslc HalfDork
11/12/12 7:48 p.m.
Niiiice ...
p9R4NDoMmmVazc3b4601AIkJjRPHsDEH1wz9eWV2QsIriocu8wD8yJkSHa167zmq
