Per Schroeder
Per Schroeder PowerDork
10/22/10 10:54 a.m.
Projects like the LeGrand are dangerously easy to work on—no creature comforts or bodywork to get in the way. As a result, when we started working on the front suspension, we also looked at the braking system and realized just how old and craptacular the original Girling master cylinders were. We pulled them all apart and replaced them with new …
sbarton
sbarton
10/22/10 11:10 a.m.
I saw in the Nov 2010 issue that you guys used Staubli Dry Break Connectors and that they were $100 a pair.
Where did you get them and what model numbers did you use?
I would like to get a pair for disconnecting a fuel cell.
Thanks.
nderwater
nderwater PowerDork
10/25/10 11:24 a.m.
Why did you guys opt for a plywood splitter over sheet aluminum, fiberglass or even carbon fibre?
Per Schroeder
10/25/10 1:37 p.m.
For right now, it's super cheap. $32 for a sheet of hardwood plywood. It weighs 6lbs when cut to dimensions and it's very strong---better than Aluminum or fiberglass. Once we sort out the exact size/shape we want, we'll be replacing it with carbon/honeycomb.
nderwater
nderwater PowerDork
10/25/10 10:04 p.m.
I forget how tiny this car is - it looks like it would be much heavier!
Per Schroeder
10/26/10 2:58 p.m.
Yep, the splitter is 58" x 18", so it's not too big.
93dlz84Z4iBRz0gXPKH9Gut2ExNJCEYvP52TMVAo7tYLyzokXccov3a3pYq6g5wj
