Taiden
Taiden HalfDork
7/25/11 7:03 p.m.
I've always been of the belief that muffler gaskets should never have any kind of sealant. But more and more I am running into people who swear by things like RTV Ultra Blue, or RTV red... not AS a gasket, but in addition to a gasket.
I'm starting to find now that even with fresh gaskets my exhaust systems aren't sealing as well as I would like.
I am curious what GRMers think...
to sealant, or not to sealant?
KATYB
KATYB HalfDork
7/25/11 9:05 p.m.
on gaskets i have always made it a ritual to use either copper coat or copper rtv. sometimes in replacement of the gasket but often just to be sure it seal.... ultra blue would burn out right away.
awdxboost
awdxboost New Reader
7/25/11 9:09 p.m.
ive used the copper rtv with success
fasted58
fasted58 Dork
7/25/11 9:37 p.m.
gasket should seal by clamping force alone. IMO, any viscous coating: copper spray, aliminum hi-temp paint, anti-seize etc. will wet the gasket or donut and help deform it to the fit of the flanges.
daytonaer
daytonaer Reader
7/25/11 11:55 p.m.
Red rtv. I've cobbled lots of exhaust repairs, works.
benzbaron
benzbaron Dork
7/26/11 12:39 a.m.
All I know is a taiwanese 1.75" vs american 1.75" doesn't seal all that well. I have used copper tape to seat an exhaust but that isn't a great solutiion.
donalson
donalson SuperDork
7/26/11 1:13 a.m.
I know the turbo dodge guys use bearing grease (non synth) on the turbo downpipe flange and turbo flange to stop it from leaking...
44Dwarf
44Dwarf Dork
7/26/11 6:51 a.m.
Depends on the gasket type. White fiberus (header gasket to block) one get soaked in BOILING hot water for 5 minutes before being installed. It softens and swells the gasket and lets it form to the header better. Compressed metal coned type (look like brillo and lead) i normaly just make sure flanges are smooth and install dry. Metal flat like two bolt flanges get red RTV
If its a work in progress. All pipes get red RTV and 2 spot welds with very little clamp presure. This helps with removal down the road.
44
iceracer
iceracer SuperDork
7/26/11 8:23 a.m.
How many sealing compounds will stand up to exhaust temperatures ?
Ranger50
Ranger50 Dork
7/26/11 8:43 a.m.
iceracer wrote: How many sealing compounds will stand up to exhaust temperatures ?
I know Permatex Ultra Copper RTV has been sealing up my broken exhaust manifold, it is also missing one manifold to head bolt, for 30k so far..... I have had to replace it once because I couldn't stand the exhaust tick all the time.
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
7/26/11 8:56 a.m.
DEI/Spal is selling a gasket eliminator that's specifically meant for turbo/exhaust applications.
http://www.designengineering.com/press/spa-turbo-usa-gasket-eliminator-and-flange-sealant
hvYaVuCipTVOu1nZ89xaRIV5R14HqJk8h85moaUwO4l9fTsjK9HqxyXR7u8ejs9K
