pres589
pres589 HalfDork
6/20/10 2:37 p.m.
In reply to Xceler8x:
Lincoln Versailles had discs on the back end, hung off of a 9" rear. At one time it was a very popular junkyard fine but other rear axles have come along to replace these somewhat rare pieces as prize finds.
CaptainSpaulding
CaptainSpaulding New Reader
6/20/10 3:26 p.m.
This 83 GT turbo run 11s
CaptainSpaulding
6/20/10 3:27 p.m.
How about a SVO with a Volvo head swap.
CaptainSpaulding
6/20/10 3:28 p.m.
CaptainSpaulding
6/20/10 3:29 p.m.
another 83
CaptainSpaulding
6/20/10 3:30 p.m.
capri rs turbo
CaptainSpaulding
6/20/10 3:31 p.m.
lewbud
lewbud Reader
6/20/10 5:34 p.m.
CaptainSpaulding wrote: How about a SVO with a Volvo head swap.
I just had a tingly feeling run up my leg.
novaderrik
novaderrik Reader
6/20/10 5:44 p.m.
what Volvo head swaps onto a Ford 2.3 engine? is it an easy and cheap junkyard swap?
CaptainSpaulding
6/20/10 5:55 p.m.
Volvo twin cam 2.3.
Is it easy? Depends on the fab skills. I t will bolt on and the cyl bores are in the right place
www.turboford.org
gamby
gamby SuperDork
6/20/10 6:15 p.m.
OH, I LIKE THAT.
Great car.
belteshazzar
belteshazzar SuperDork
6/20/10 7:25 p.m.
here was my '89 LX swapped one...
Lugnut
Lugnut HalfDork
6/20/10 7:28 p.m.
I keep thinking about that 16v Volvo head swap, but it's too much work for me even on my Volvo.
Schmidlap
Schmidlap Reader
6/20/10 8:02 p.m.
With the SVO's, isn't there an issue with the front control arms not being made anymore by anyone, and the bushings can't be replaced? Or has the enthusiast crowd developed a solution?
Bob
CaptainSpaulding
6/20/10 8:32 p.m.
Schmidlap wrote: With the SVO's, isn't there an issue with the front control arms not being made anymore by anyone, and the bushings can't be replaced? Or has the enthusiast crowd developed a solution? Bob
The ball joints are the problem.
Maximum motorsports makes parts to use SN95 control arms in place of the lincoln SVO control arms.
The SVO K member is different in that it is shorter thus usimg the longer control arms. The spindle is also different in that the ball joint is bigger and the hole in the spin dle is bigger. Maximum motorsports also has ball joint adapters so you can use the spindles on other fox cars.
CaptainSpaulding
6/20/10 8:39 p.m.
Mine. No longer 2.3t powered. Now it has a cmc legal 5.0 in it.
oldeskewltoy
oldeskewltoy Reader
6/20/10 11:33 p.m.
hehehehehe......
its been a loooong time since I owned my Fox chassis 1980 Turbo(blow through) Capri with the TRX suspension, and the Recaros...
I added a few Racer Walsh go fast bits(variable boost with alcohol/water injection, and a full Koni suspension package) I also upped the TRX tire package from the 190/65/390, to the 220/55/390
CaptainSpaulding
6/20/10 11:49 p.m.
The old blow thru carbed cars also loved exhaust work.
FjVWloIJQGnFuRqcrMTwAbLmHSpvmZjPk9RQDogQxnOOT7R2kfe2OlYhQ809DTdH
