Trackmouse
Trackmouse SuperDork
8/28/17 2:45 p.m.
Apperently a 2 bolt flange, 2" diameter ball and socket header flange set doesn't exist. I can find 2.5" all day. I did find a female end from Walker, but can't find the male end. Wtf....
Trackmouse
8/28/17 2:49 p.m.
Oh, and I am going from 2" on the header, to eventually 2.5", any thing that can adapt to that would be gooder-er.
Edit- I kinda found this. Hedman
It says the outlet side is 2" though. Can these be reversed without killing airflow? I'm pretty sure the female end should be the inlet side right?
jfryjfry
jfryjfry HalfDork
8/28/17 4:35 p.m.
I don't see why you couldn't reverse it. Should work well
Trackmouse
8/28/17 5:00 p.m.
I was just worried about the way they fit together and if that would cause turbulence within the connection
Streetwiseguy UltimaDork
8/28/17 9:35 p.m.
I think the female end is more often the outlet, on factory exhaust.
HXViDKW108Or3XagDTmxRdtDPqOOhIkO1bLFVXBnQWA7lmWTYTF7KWimRUSrH8LB
