1 2 3 4
pinchvalve
pinchvalve MegaDork
6/11/15 10:54 a.m.
I know we use "Hayabusa Engine" as the dream for a bike-engine project, but has the H2r become the new top-dog? I mean, OEM turbo.
stroker
stroker SuperDork
6/11/15 11:12 a.m.
In reply to pinchvalve: good luck finding one.
edizzle89
edizzle89 HalfDork
6/11/15 12:14 p.m.
pinchvalve wrote: I know we use "Hayabusa Engine" as the dream for a bike-engine project, but has the H2r become the new top-dog? I mean, OEM turbo.
i think you mean supercharger
6/11/15 1:41 p.m.
You know, there might be something in there, in building add on body kits for Exocets, especially with styling nods to 50s and 60s sports cars.
We might be on to something.
JFX001
JFX001 UberDork
6/11/15 2:15 p.m.
Turbo 'busa powered Smart Car?
https://www.youtube.com/watch?v=yFUDU1lYdJ8
tuna55
tuna55 UltimaDork
6/11/15 2:20 p.m.
Appleseed wrote: You know, there might be something in there, in building add on body kits for Exocets, especially with styling nods to 50s and 60s sports cars. We might be on to something.
If I had the cash I would do that right now. I think that's capable of producing something amazing and beautiful.
wearymicrobe
wearymicrobe SuperDork
6/11/15 3:25 p.m.
stroker wrote: In reply to pinchvalve: good luck finding one.
Give it a couple weeks they just came out.
Adrian_Thompson
Adrian_Thompson UltimaDork
6/12/15 7:40 a.m.
I've mentioned Davrian's before on GRM, ubt I've finally found a pic of my old car. Sorry for the really E36 M3ty images, but these were scanned from a couple of old prints.
Not 100% sure on the weight, but most agree easily less than 1,000lb's on the road. They are a fiberglass monoqoue made in three pieces. A lower floor, an inner tub and a roof section. The two lower parts are bonded together with expanding foam between them and you sit on the lower tub, no seats. Very light Hillman Imp running gear, rear mounted all alloy engine. It should be easy to put a bike engine back there. Semi trailing arm rear suspension with swing arm front suspension that workes way better than it sounds. The car below had no heat, no blower of any kind. Plastic side and rear windows. You lowered the windows by pulling a pin, sliding them down by hand so no useless heavy window mechanism. It was even watertight when parked undercover. Yeah mine was rough, but I was 20 at the time and broak. Still, it was my only car for about 18 months and you could easily fit a weekends worth of food and cloths behind the 'seats'
Other better pictures of other peoples cars
A Davrian too hard to find on this continent? Then get a regular Imp, still very light.
This is a stock shell with outer panels removed to be replaced in glass.
HEre's another with flared arches. Still a steel tub under there.
Suzuki engine in the rear. The rear window surround is cut away at the bottom to fit it as it's mounted virticaly where the stock Imp engine was mounted canted to the right at (from memory) 45degrees to the right.
A bone stock Imp was only around 1,500lb's with full interior and err 'safety' features. They didn't even have a fuse box, everything was hard wired!!
Kreb
Kreb GRM+ Memberand UltraDork
6/12/15 9:29 a.m.
If things go according to plan, I should be able to sell you the pieces for one of these in not too long. circa 1000 lbs. with a bike engine, a bit more with a Duratec.
stroker
stroker SuperDork
6/12/15 9:56 a.m.
what about a stripped 914?
edizzle89
edizzle89 HalfDork
6/12/15 10:21 a.m.
a dune buggy with front mount engine and some IRS out back could probably be ~1500 lbs
DWNSHFT
DWNSHFT HalfDork
6/12/15 10:26 a.m.
Kreb wrote: If things go according to plan, I should be able to sell you the pieces for one of these in not too long. circa 1000 lbs. with a bike engine, a bit more with a Duratec.
For the win!!!
kanaric
kanaric Dork
6/12/15 10:28 a.m.
I think someone here has this E7x era Corolla. They are like 1800-1900 lbs according to google.
Kei cars like this Hond Beat are absurdly light.
Mezzanine
Mezzanine Reader
6/12/15 10:30 a.m.
GGA. Everything about this is right. Please follow through and make this kit. I won't be able to get one for a little while, but I will get one.
Jamey_from_Legal
Jamey_from_Legal Reader
6/12/15 10:43 a.m.
The Porsche Spyder replicas are light chassis. I have read about some with early 911 motors being brought in under 1300 pounds. I think they're getting done with Subi 2.5 water cooled motors now too.
Kreb
6/12/15 10:46 a.m.
GGA. Everything about this is right. Please follow through and make this kit. I won't be able to get one for a little while, but I *will* get one.
We plan to run a limited batch of bodys shortly, which will in turn pay for development of a full kit. Don't worry, we'll be blowing our horn!
Rusted_Busted_Spit
Rusted_Busted_Spit GRM+ Memberand UberDork
6/12/15 11:20 a.m.
I wonder if that would fit over a naked Elise?
Woody
Woody GRM+ Memberand MegaDork
6/12/15 12:08 p.m.
Giant Purple Snorklewacker wrote:
Kreb wrote:
MacDubois wrote: Renault Dauphine ~1430 lbs Can usually be found in fields on Craigslist. I always wanted to do a big snowmobile engine in one (because electric reverse) but a bike engine would work too.
That's a great idea. I love the way that they look, but they are also known as steaming POS. Now if you got rid of everything but the pretty stuff......
I love that thing. Is there a coupe?
Do you really need a coupe?
TIGMOTORSPORTS
TIGMOTORSPORTS HalfDork
6/13/15 8:37 a.m.
In reply to Adrian_Thompson:
Davrian - never heard of it - looks awesome - took me on a rabbit trail
https://en.wikipedia.org/wiki/Davrian
This thread is causing me to view my junk now as heavy junk
datsuntech
datsuntech None
10/19/21 5:28 p.m.
1 2 3 4
O3qiw4ZD9zdsICifZXCoNBzRs56DCYst9TtjB0dmcQFGI7VwQoeqzsyK2Rj0FsKC
