LanEvo
LanEvo GRM+ Memberand Reader
9/1/16 9:39 p.m.
Let's say you've got a well-balanced, RWD racecar that (for a variety of reasons) is limited to a 15x7" wheel. The car weighs 2800 lbs wet. You can fit 225 mm tires under the fenders. Should you?
In other words, should I stick with 205/50-15 tires (better fit on the wheel) or squeeze on some 225/45-15 rubber? Will the pinched-in sidewalls and potentially distorted contact patch negate any extra grip from the additional ~1 inch of tread width?
The tires in question would be either Hoosier R7 or Hankook Z214.
Dusterbd13
Dusterbd13 PowerDork
9/1/16 10:07 p.m.
I've run 235/60 on 15x7 for years with no ill effects. But that is in muscle car land.
bmw88rider
bmw88rider GRM+ Memberand Dork
9/1/16 10:22 p.m.
Look at how many ES miatas ran 225 tires on 6" rims and won all the time. Sure the 8" or 9" rim would be more square but I wouldn't pass up more rubber all day long.
moxnix
moxnix HalfDork
9/1/16 10:40 p.m.
Track or autox? How much power?
Robbie
Robbie GRM+ Memberand UltraDork
9/1/16 11:16 p.m.
I had 245 Hoosier a7s mounted on 16x6.5 wheels for the challenge. (I already had the tires).
One thing I notice is that the Hoosier+wheel is like 2x the weight of a stock wheel+ tire.... not good.
I'm still gonna run em, but crap they are heavy. Might be worth paying a bit of attention to the weight.
daeman
daeman HalfDork
9/1/16 11:56 p.m.
I've got 215/50r18 hankook ventus v12's on 18x6jj Mitsubishi Pajero rims. They look alright and have been on for 2 years with no Ill effects. They seem to be wearing evenly and I don't feel much sidewall flex.
LanEvo
9/2/16 5:56 a.m.
moxnix wrote: Track or autox? How much power?
Track only (vintage racecar). Power is about 200 hp.
rslifkin
rslifkin Dork
9/2/16 7:22 a.m.
With tires at that level, usually the sidewalls are stiff enough that even with a bit of pinch, the extra rubber will help you, as the sidewalls don't allow enough flex / rollover to waste the extra contact patch.
You will give up a little steering response and feel with the tires pinched, but depending on the car and driver, that's not necessarily a big deal.
KyAllroad
KyAllroad UberDork
9/2/16 7:42 a.m.
I've done 275 Hoosiers on a 15x7.5 wheel. It is a bit pinchy, a 225 on a 7 really should be fine, Hoosier construction does well with a narrower wheel.
z31maniac
z31maniac MegaDork
9/2/16 7:59 a.m.
Hoosier sidewalls != street tire sidewalls.
ebVPiIUjcjjqBMEz9KNFsFzMT3hd5yeSnIvPBvdLl6TsJEkiOzAmeS5hr7cIqdUp
