bravenrace
bravenrace MegaDork
11/30/15 7:49 a.m.
Look in the upper part of this picture under the tube. It looks like a plug at the back of the left side cam maybe? I don't know much about these engines yet, but this thing is leaking bad.
chiodos
chiodos HalfDork
11/30/15 8:22 a.m.
Hard to tell how far up it goes but perhaps the valve cover gasket. I'm not accustomed to the 1.8 motors but I know there's a cam sensor back there too idk if it's passenger side rear or driver side but that could be another culprit.
EvanB
EvanB GRM+ Memberand UltimaDork
11/30/15 8:29 a.m.
On the NB there should be a plug where the cam sensor used to go on the back of the exhaust cam.
RedGT
RedGT Reader
11/30/15 8:43 a.m.
EvanB wrote: On the NB there should be a plug where the cam sensor used to go on the back of the exhaust cam.
And on the cars with CAS's there it is a super common leak point. (I know you know this, just pointing it out for him)
bravenrace
bravenrace MegaDork
11/30/15 8:56 a.m.
In reply to EvanB:
I think that is what is leaking. The valve cover goes around the top of this plug and is not leaking. The plug itself seems to be leaking. Is there a seal that goes in it?
11/30/15 10:08 a.m.
IIRC it's basically just a freeze plug. I would say this is a case for RTV.
bravenrace
bravenrace MegaDork
11/30/15 10:32 a.m.
In reply to Keith Tanner:
Thanks. Just wanted to make sure I didn't need to order anything before taking it apart.
bravenrace
bravenrace MegaDork
11/30/15 11:29 a.m.
The leak appears to be coming from the round plug in the upper left or the pipe plug under it as shown in this picture.
calteg
calteg HalfDork
11/30/15 12:23 p.m.
Pop the valve cover, push that plug out and RTV it. Do the valve cover gasket while you're at it.
UuW08Ggmk9mXpEPUiGFMTrRsAp2mYLdsPWQWKd4z20ZNBTJ6nzrjvLIwKQ63A0Xk
