Hey all, looking for some Miata advice.
Got a 94 shell/body that I put the good running motor from my 95 into. Having a few issues.
The main issue is that when it first starts up it's fine and revs ok, but then after 20 seconds or so it won't rev past 2200rpms.
Known issues:
Vacuum Leak: (Resolved) There was a vacuum leak, on the intake manifold, one of the nipples that gets plugged. I plugged it up and now it idles better, the RPM issue still persists.
Cam Sensor: In the process of putting the motor in, I damaged the (intake) cam sensor. I pulled the sensor on my spare engine and replaced it. It seemed plug and play, unless there is some process to installing them properly that I am totally unaware of.
Oil Pressure Sender: First time I started it up I noticed no oil pressure, according to the gauge. Verified it did in fact have oil, and I hadn't changed anything else since pulling the motor that would affect oil pressure (ran fine previously) so I figured I just missed plugging it in that sensor. I was able to drive around for a while, then the RPM issue came up. Looking into it, 94 was the only model year with the 1.8l engine that had the old (real) oil pressure sender, and 95 and newer had a essentially a dummy light sender. After plugging in the wire to the 95 sender, I get no reading still.
So, is it possible that it is going into some sort of limp mode due to reading 0 oil pressure?
As in, would buying the proper ~$200 90-94 sender likely fix my issue?
MAF Wiring: When I put the engine into this shell I found that the insulation on the MAF sensor wires was gone, and the black wire (with green stripe I think?) was cut and stripped at both ends, but at the harness side there were two black (with green stripe?) wires cut and stripped. Right now if I put alligator clips between the two at the harness and the one at the MAF, it doesn't start, but if I also ground that connection it starts up fine. Looking at wiring diagrams, if I am actually reading it right, it seems like that wire should be ground… Is that right? Not exactly sure why someone would mess with the wiring there, but maybe the chipmunks got to it at some point??
