jrao83
jrao83 New Reader
11/19/08 5:35 p.m.
Kramer wrote: Can't the stats on a Ranger be put in backwards? I thought there was something screwy about this truck, with regards to the stat.
not sure about on others but there is no way to get this one in backwards
jrao83
jrao83 New Reader
11/19/08 5:38 p.m.
derekshannon wrote: You should be able to blow out a candle held in front of the dash vents while standing still with the blower on high setting. You should AT LEAST hear the blower blowing. Let's make sure the blower is blowing while in Neutral/Park. If not, blower motor (or circuit/fuse) is the culprit. I had to replace mine in my Bronco with a used on for like $20.00 and it solved it. Take the motor out and put 12v to it and see if it spins. EDIT: Hmmmm, but if the needle doesn't show it getting warm...
The blower works the same if I am parked or moving no real difference. Not sure if its strong enough to blow out a candle but moves a good little bit of air
jrao83
jrao83 New Reader
11/19/08 5:43 p.m.
now for a update, I drove to work this morning its about a 30 min ride. When I got there I opened the hood and was able to grab the radiator hose with my bare hand. I had heat on the way but not much. I did notice there was little to no coolant in the line with the truck still running. I also stuck my finger in the radiator and wouldnt you know its cold. How in the world has this thing not blown up????
QvnIhPUD5QM0bMTHXDN5YB1HSpv5p4AnhLP4ZI5SiTY62PzYLnljXJRA4JaeuNRs
