neckromacr
neckromacr Reader
3/27/11 11:35 p.m.
I'll cut to the chase: I have a car that originally had a manifold/downpipe/cat set up that now has a cat-less header welded straight to the midpipe. I need to get it past tailpipe emissions, and without a cat obviously it's failsville.
I'd like to keep the header since it's in good shape and flows a little better.
I was thinking of taking the mid pipe resonator out and welding in a universal cat. In the OEM setup the only O2 is pre-cat and technically it'll have all the proper emissions components, just not in OEM configuration.
I figure I'd tap the GRM community's wealth of knowledge and see if this was a terrible idea.
Nitroracer
Nitroracer SuperDork
3/28/11 12:43 a.m.
Might depend on how closely your state follows the inspection rules. Some places will not allow the position of the cats to be changed.
I would call a local exhaust shop and run the idea by them.
davidjs
davidjs Reader
3/28/11 8:30 a.m.
I'm not sure how far back you are looking at putting it, but you may have issues getting it hot enough, so I would probably make sure you ran it hot for quite some time before getting it sniffed, just in case?
iceracer
iceracer Dork
3/28/11 9:16 a.m.
Each state has different regulations, best to check locally.
3/28/11 10:56 a.m.
yes.. I would think that getting it as close to the header as possible would be best
Travis_K
Travis_K Dork
3/28/11 11:22 a.m.
Check the local regulations, in california you would be putting it back to stock, but other places dont care at all, it just depends.
neckromacr
neckromacr Reader
3/28/11 3:44 p.m.
Talked to a friend in the DMV, Delaware only cares that its in the exhaust system somewhere.
But the location in relation to the header is why I asked here, thanks.
For comparison's sake TT's exhaust mimic's the OEM one pretty well. The midpipe resonator would become the cat.
r1qfyzg9yVA8eXN0XQJf3I3rlkVBK9R3mZooF4JcKAh6DGYJarycB6J1w8Sd1S3z
