tuna55
tuna55 MegaDork
11/22/17 8:47 a.m.
Is anyone sitting out there waiting to take a few large fine pitch bolts and put a tapered hole in each one? if so, let me know!
Dusterbd13
Dusterbd13 MegaDork
11/22/17 8:55 a.m.
I was going to post a similar thread for header flanges.  You beat me to it!
I can talk to goodman here in town, especially if you have drawings of what you need
tuna55
tuna55 MegaDork
11/22/17 9:15 a.m.
Not yet, I need to talk to a good machinist first. It should be pretty easy, but I am not smart enough to get it made myself.
Dusterbd13
Dusterbd13 MegaDork
11/22/17 9:16 a.m.
Ok. If you strike out, ill get you in contact with goodman
The_Jed
The_Jed PowerDork
11/22/17 9:38 a.m.
I might know a guy.
Shoot me an email with some specs and dimensions.
jimbbski
jimbbski Dork
11/22/17 10:31 a.m.
Are the holes to be used for safety wire?  Or are the holes in line with the bolt?
akylekoz
akylekoz HalfDork
11/22/17 11:39 a.m.
I could be persuaded to make some chips.
tuna55
tuna55 MegaDork
11/22/17 1:37 p.m.
In reply to jimbbski :
axially, through the length of the bolt
tuna55
tuna55 MegaDork
11/22/17 1:37 p.m.
In reply to akylekoz :
Cool! Will send a PM.
jimbbski
jimbbski Dork
11/22/17 5:49 p.m.
oldopelguy
oldopelguy UltraDork
11/22/17 10:38 p.m.
See also: gundrilled bolts.
I have a new to me 16x60 lathe. I'd be happy to chuck something in there but I haven't even spent the night at the holiday inn yet....
tuna55
tuna55 MegaDork
11/24/17 10:40 p.m.
Those gundrilled bolts are exactly the ticket.
So I am thinking a 3/4-16 drilled bolt in a tapped hole in my knuckle. I can buy a tapered reamer and put the taper in the bolt, but there is a problem.
If I do this, I will not have enough room for a bolt head. The knuckle arm is 1" deep, but I have to room on either side for the bolt head since on one end is the tie rod and the other is the nut for the tie rod.
If I pull the bolt head off, and thread it in, the tie rod nut with a good washer should hold it in place. That and some red loctite on the threads might work.
Thoughts? There is always the risk of the new threaded spacer unscrewing and falling out of the bottom of the knuckle arm. The loctite will help, perhaps a weld bead or two makes it more serious?
I am still struggling with that. Maybe I drill radially through the spacer but not into the ID and run in a split pin additionally through both the spacer and the knuckle arm.
tuna55
tuna55 MegaDork
11/25/17 8:25 a.m.
The minor diameter of a 3/4-16 bolt is 0.6718 whereas the largest od of the taper is .0623. I think that’s enough.
Fueled by Caffeine
Fueled by Caffeine MegaDork
11/25/17 11:56 a.m.
So you’re looking for a way to change the diameter of the hole on the knuckle?
Fueled by Caffeine
11/25/17 12:01 p.m.
tuna55
tuna55 MegaDork
11/27/17 6:34 a.m.
Sort of. Go from a big straight hole to a smaller tapered hole, and also have some amount of adjustment axially along the hole.
Fueled by Caffeine
11/27/17 7:21 a.m.
In reply to tuna55 :
Look around for these repair bushings and then use an extended ball joint.
SaltyDog
SaltyDog Reader
11/27/17 8:17 a.m.
I'm assuming this is for your tie rod end conundrum.
I don't think you need to worry about the new threaded sleeve backing out. On one side of the sleeve, will be the tie rod end, on the other the tie rod end nut, which will sandwich the sleeve into the knuckle, so I don't think you will need a nut.
I would still use red loctite on it, however.
Regarding the castle nuts you discussed in the video, tie rod ends and ball joints use either the castellated nut and cotter pin or a lock nut. You don't want them to let go!
My only concern with this approach would be to make sure there is still enough metal around the slightly enlarged tie rod end mounting hole.
I can help you with the machining as well if needed, but I am in Illinois. If no options closer to home are available, let me know. I would be glad to help get the Tuna Truck closer to being back on the road!
tuna55
tuna55 MegaDork
11/27/17 9:10 a.m.
In reply to SaltyDog :
Yes it is!
My problem with the castle nuts is that they encourage you to overtorque or udertorque the nut to get it to line up. On a thread that small it can make a large difference.
I agree that I won't need a nut. I think I will buy a tapered mill or tapered reamer and one of those hollow bolts and get to work. Red Loctite is super useful, and will likely be permanent given that this area is under no heat.
The arm where I am putting this hole is large, I think about an inch across. My measurements (and the truck) are at home.
Thanks for the advice!
tuna55
tuna55 MegaDork
11/27/17 9:21 a.m.
And also, wow, those tools are expensive.
tuna55
tuna55 MegaDork
11/27/17 9:48 a.m.
More questions.
I believe my tie rod is called "2 inches per foot" but I don't know what that means. Is that the radius or the diameter?
I think real tapered endmills are sold from the radius angle from straight. I do not know for reamers. How do I make this match?
SkinnyG
SkinnyG SuperDork
11/27/17 10:00 a.m.
The taper changes 2 inches over a 1 foot length.
tuna55
tuna55 MegaDork
11/27/17 10:09 a.m.
yup, I called Moog
2" per foot apparently ~= 10 degrees ish.
SaltyDog
SaltyDog Reader
11/27/17 10:16 a.m.
Since it is a relatively short distance, and the angle can be determined, you should be able to bore the taper with either the compound on an engine lathe or in a CNC lathe, saving you the cost of the tool.
tuna55
tuna55 MegaDork
11/27/17 11:06 a.m.
but buying the tool may save the cost of paying a person with a lathe.
1yGQXxSwGBT2mhLpmg9bWj93Xq1kGhy7rLYoDjvkklgGyvTmGeDz1LYEi0NCxqMQ
