Dusterbd13-michael
Dusterbd13-michael MegaDork
12/11/18 12:17 p.m.
So, challenge car needs a different clutch master.
Must be 7/8 bore, or slightly bigger.
Must have a flare fitting for the line.
Metric or standard or bubble or inverted female flare doesn't matter. Im equipped for all.
Must fit a flat firewall, so 90 degree-ish mounting surface
Must be cheap. Im hoping to beat 49.99 by a LOT.
junkyards are cool.
So, what do we have/options are there?
This is literally the only thing kerping me from test driveing and starting to shake it down....
Curtis
12/11/18 12:27 p.m.
Look to GM intermediate cars from the 70s/80s.  Earlier ones I think were 7/8" and later ones were metric but very similar in bore size, they just measured it in MM.... but I could be misremembering and they are 1"
Last one I bought from an undercar wholesaler was $29.
Vega, Monza, and manual-brake vette's from the 70s used a 7/8" bore
80s Dodge K-cars used 7/8".  Be cautious that they have a pretty short stroke, so volume may be an issue.
65-67 Mustang manual brakes were 7/8" but that is a single
80s Ford intermediates (like Fairmont) used a 7/8"
83-87 Chevettes used 7/8"
Edit..... nevermind.  You need a clutch master.  I was thinking brakes.
Apexcarver
Apexcarver UltimaDork
12/11/18 12:29 p.m.
early sprites are that size, but the cheapest moss has is $70     They arent the most reliable, but you would get two bores out of one master (both in one unit, clutch and brake, same bore)
Dusterbd13-michael
12/11/18 12:38 p.m.
In reply to Curtis :
I actually looked at a couple of single reservoir brake masters, but they will bot clear the space i have. Which sucks, because theres one for 22 bucks at the flaps....
44Dwarf
44Dwarf UberDork
12/11/18 12:38 p.m.
You can buy a bare tilton from summit for $63 but then you'll need to find someone with the reservoirs laying around. (I think i have the left overs of a few "Kits")
dclafleur
dclafleur New Reader
12/11/18 12:42 p.m.
I think the '87-94 Cavalier Master Cylinders were around that size.
weedburner
weedburner Reader
12/11/18 12:46 p.m.
'94 S-10 w/ 4.3 used a 13/16" slave, RockAuto shows the cheapest version for $21.79
Grant
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UberDork
12/11/18 1:09 p.m.
7/8" bore I can find under $20 on RockAuto:
88 Ford Bronco, $15.76
DORMAN CM640046 for 2002 Civic (appears to be the wrong bore, hooray for Dorman berkeleying up?) $17.65
AUTOSPECIALTY/KELSEY-HAYES Q85007 for 1989 E150 $11.82
Edit:  I also have a box of random racing brake cylinders and stuff at home, I can go through that for you if you want.
Dusterbd13-michael
12/11/18 1:25 p.m.
Ok, i must be missing something.  Tge roll pin the pictures denotes a special fitting, right? Or is there a way to tap to npt and use a brake flare fitting adapter?
Ot am i just dense?
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UberDork
12/11/18 1:28 p.m.
The plastic master cylinders do tend to have weird plastic line connectors, yeah.  Not sure about the viability of tapping for a regular fitting.  I think the Civic MC I posted has a real flare fitting though.  I'm going to keep looking.
dclafleur
12/11/18 2:05 p.m.
Russell makes some clutch adapter fittings that can be used to convert over to AN style lines although you'll probably blow your entire budget on the fittings and lines.
Dusterbd13-michael
12/11/18 2:35 p.m.
I already have the braided line, but the adapter fittings are a budget killer.
weedburner
weedburner Reader
12/11/18 4:57 p.m.
The oem lines and braided lines are both typically plastic tubing with a protective cover. You may be able to salvage that  special oem slave fitting by cutting lines somewhere in the middle, push back the covers, and join/adapt the oem to your braided line using common hardware store compression fittings.
Dusterbd13-michael
12/11/18 5:41 p.m.
Really????
You think compression fittings would hold?
weedburner
weedburner Reader
12/11/18 6:13 p.m.
Speedway sells a nylon brake line kit that uses compression fittings... https://www.speedwaymotors.com/Speedway-Lightweight-Nylon-Racing-Brake-Line-Kit,1993.html
It's rated to 900psi burst, clutch systems are usually less than 400psi.
Grant
Patrick
12/11/18 7:42 p.m.
I have a brand new master for 80’s gm a body (yeah, manual chevy celebrity stuff) doing absolutely nothing in my dad’s garage i think.  Factory pre bled with reservoir, line, and slave all as one unit.  I can check next time i’m over there.  I don’t think it’s gone anywhere.
Dusterbd13-michael
12/11/18 8:36 p.m.
Cool. Just let me know!
Dad really wants to trst fit a single reservoir brake master.  So we may try it tomorrow night after work....
Matt
Matt New Reader
12/12/18 9:29 a.m.
i think my 85 iroc Camaro has a 7/8" clutch master. its got a remote reservoir as well.
Dirtydog
Dirtydog GRM+ Memberand Dork
12/12/18 10:17 a.m.
Doing a little reading, and found this.   Hope it gives some insight on the clutch issues.  Rock Auto has the clutch master for around $20.00
https://forum.miata.net/vb/showthread.php?t=246366&highlight=clutch
https://www.rockauto.com/en/catalog/toyota,1986,land+cruiser,4.2l+l6,1276556,transmission-manual,clutch+master+cylinder,1996
Dusterbd13-michael
12/12/18 10:48 a.m.
In reply to Dirtydog :
I had found similar posts. But in another thread we worked out the math for my hydraulic throwout bearing setup that I am running and proved that 7/8 was the size I needed at a minimum. Unfortunately the Land Cruiser stuff is only three quarters.
AngryCorvair
12/12/18 11:31 a.m.
I might have an Airheart 7/8” MC on the shelf at home, or it may have been in the box of goodies I gave to another board member (after posting here) when I was cleaning the garage a few months ago.  I can check on Friday.
Dusterbd13-michael
12/12/18 11:34 a.m.
In reply to AngryCorvair :
Please! That would be fantastic!
CJ
CJ GRM+ Memberand Reader
12/12/18 12:42 p.m.
Dusterbd13-michael
12/12/18 12:52 p.m.
In reply to CJ :
I have that one in my cart. But have no idea what i would need for plumbing.
tr8todd
tr8todd Dork
12/12/18 5:53 p.m.
The dead pedal on stand up fork lifts use a clutch master.  Back when I worked at a huge food distributor warehouse, I use to bring home boxes of them after they started leaking.  It was easier and cheaper to just replace them rather than rebuild them.  They mostly looked like Tilton with a removable res, but some looked like the Girling ones.  They were much cheaper than the ones slated for cars.
2Pc7esgwaRDlmEuj3YlGf6ZgUbuky9Feh38xt4DjlQ1zlKxgepHqgGlcrIhb6Q9E
