bluesideup
bluesideup New Reader
12/15/09 5:44 p.m.
My wife's cousin has a Focus four door appliance car. She drives like she is suffering from rectal cranial inversion and it sounds like a wheel bearing is worse for wear. I've researhed and found advice saying to replace the entire knuckle as well as others saying to have a machine shop R&R the bearings. I'm sure you guys have experience with this vehicle.
The car makes a howling noise in right turns and is silent in left turns. It also makes lane changes by itself. Given that info I would suspect the left front bearing since it's loaded in right turns. Does that sound correct? I know how to check the bearings once I have it lifted up but I want to minimize my time invested in this project.
Thanks!
iceracer
iceracer HalfDork
12/15/09 6:32 p.m.
Sounds about right. You can replace the whole knuckle or just have a new bearing pressed in.Of course you have to remove the knuckle for that.
bluesideup
12/15/09 8:03 p.m.
Do I need to order the hub repair kit with that includes the hub and bearing or can I just buy the bearing itself and reuse the hub?
ignorant
ignorant SuperDork
12/15/09 8:12 p.m.
How expensive is the whole assembly? If it saves you time and isn't that much more money, I'd do the knuckle.
Giant Purple Snorklewacker
12/15/09 8:15 p.m.
Give raxles.com a call for a price. He was a really nice guy and saved me a ton of $$ when my wife's Passat shat its front outers. It was cheaper to have him ship me 2 new axles than it was to get mine locally R&R'd.
mistanfo
mistanfo Dork
12/15/09 8:28 p.m.
AND, raxles is a GRM advertiser.
rjones33
rjones33 New Reader
12/16/09 12:29 p.m.
AND raxles is fun to say.
bluesideup
12/17/09 12:14 a.m.
I will check it out. Rockauto says a Timken bearing is $28. Figure $8 to ship and maybe $50 for the machine shop to R&R (this is Orange County after all). Is a complete new knuckle going to be cheaper than $86?
12/17/09 1:28 a.m.
raxles... it sort of rolls of the tongue
bluesideup
12/17/09 9:02 p.m.
Well I drove it and jacked it up. The car pulls to the right but it feels more like an alignment issue than a wheel bearing bad enough to cause a problem. The bearing is definitely noisy in right turns so I'll order the front bearing and see how it turns out.
Adrian_Thompson
Adrian_Thompson Reader
12/18/09 7:08 a.m.
If you have a press you can R&R the bearing yourself. It's not a hard job. Getting the knuckle off and on again is a much bigger PIA.
bluesideup
12/18/09 7:17 p.m.
Unfortunately I have not had clearance from the warden for a press yet. I'll have to do the hard work and pay someone else for the easy part.
I'll pick up a screw type ball joint separator (pickle fork will just damage the boot) and tie rod separator from Autozone rent a tool.
huW9ChbCXry12jc2FmxAsMYePXJIp3Oh9D7dK6mcTVk9hztMvcaDpuslTsKKfn5K
