i have a vw bus tranny in my dunebuggy and it pops out of r. so im needed help to figure out how to fix it thanks
ok im almost sure the gears are ok but i dont know how to check either of the other two im still trying to learn this being my first experience with vw
One reason VWs pop out of gear can be up/down movement of the nose of the transaxle. Is yours snubbed down well? My Baja Bug 30 years ago had a bit of a problem like this, and a new set of motor mounts/transaxle straps cured it. The movement can be either from bumps or from on/off throttle.
914 owner, kinda sorta the same. Look at the mounting bushings. Like jpg said, a little twist and you're back in neutral.
Bushings are easier and cheaper than a rebuild.
Dan
