fornetti14
fornetti14 GRM+ Memberand Reader
12/30/09 9:25 p.m.
Haven't found any pictures online so I'm starting from scratch. The car: '99 Neon Sport with the dual cam 4 cyl. and 5-speed. High mileage beast (250,000) Clutch went to the floor and won't come up.
Fished the cable out of the bell housing and it looks like this: Photobucket
Is that what it's supposed to look like? There wasn't any tension on it and it wasn't connected to the fork. That can't be good. Is there something missing like a clip?
Here's a picture of the top of the shift fork in side the trans: Photobucket Is there anything missing there?
The fork is sort of wobbly and I think I may have a failed pressure plate.
HappyJack
HappyJack
12/31/09 5:46 a.m.
In reply to fornetti14: Looks like it is all there. The fork shouldn't be wobbly, my bet is a failed pressure plate too. I had the same happen to me in my 98 Neon.
It's gonna be expensive though. In the Neon, the clutch is modular. The flywheel, clutch, and pressure plate are all one assembly. About $300-$400 just for the assembly.
Apparently a clutch assembly from a PT cruiser bolts in, is cheaper, and bigger. A lot of guys on the Neon forums do this swap for better performance on the turbo cars.
The cheapest way, and the way I went, is get a clutch assembly out of a 95 Neon from a wreckers. In 95, the first year for the Neon, it had the traditional type clutch. A separate flywheel, clutch and pressure plate. (some late 95 Neons did have the modular clutch)
I paid $50 at the wreckers for the flywheel and pressure plate, then $50 for a brand new clutch. It is a simple bolt in affair. No modifications.
Good luck
MCarp22
MCarp22 Reader
12/31/09 9:09 a.m.
If your neon was built in Mexico, you can disregard the stuff that HappyJack posted, the modular clutch stuff only applies to 96-99 US built cars.
Also, if you decide to swap from modular to conventional, you can find a MX built car and not just a '95.
A new modular clutch can usually be had for under $200.
John Brown
12/31/09 9:13 a.m.
Tony, call Clutch Dynamics in Lansing for that clutch. 517-321-7389, 3618 Scheffer Ave, Lansing, Mi.
Not related and no affiliation but they have built every clutch I have had for the last 20 years and have supplied a few to GRM members.
Forillydoe, give them a call
fornetti14
12/31/09 9:38 a.m.
Thanks for the tip. Carquest has the assembly locally for $179 which is much less than I thought it would be. My vin code (11th digit) is "T".
How do I tell if I have a U.S. built car?
mel_horn
mel_horn Dork
12/31/09 9:55 a.m.
fornetti14 wrote: How do I tell if I have a U.S. built car?
First digit of the VIN will be "1"
(If it's 2, blame Canada )
Other info may be required...
John Brown
12/31/09 10:01 a.m.
3 be Mecksicko.
fornetti14
12/31/09 10:06 a.m.
John Brown wrote: 3 be Mecksicko.
My VIN starts with a 3 so there we go. Thanks guys!
Anyone know how to fix the gears in the sunroof? I may have to start another post this spring for that repair.
digdug18
digdug18 Reader
12/31/09 6:32 p.m.
yeah, to fix the gears in the sun roof, you either goto the before mentioned junk yard and grab some cheap parts.
OR
weld a patch panel into the sunroof hole.
Andrew
MCarp22
MCarp22 Reader
12/31/09 7:30 p.m.
fornetti14 wrote: Anyone know how to fix the gears in the sunroof? I may have to start another post this spring for that repair.
There's a big sunroof discussion on neons.org:
http://forums.neons.org/viewtopic.php?t=40031
HappyJack
HappyJack New Reader
1/1/10 6:51 a.m.
MCarp22 wrote: If your neon was built in Mexico, you can disregard the stuff that HappyJack posted, the modular clutch stuff only applies to 96-99 US built cars. Also, if you decide to swap from modular to conventional, you can find a MX built car and not just a '95. A new modular clutch can usually be had for under $200.
$200? Getting it here by dogsled must up the price, because when I needed one in Canada here, I was quoted $380! As for Mexican cars, I'm afraid to think what they would cost to get to Canada.
MCarp22
MCarp22 Reader
1/1/10 7:13 a.m.
HappyJack wrote: $200? Getting it here by dogsled must up the price, because when I needed one in Canada here, I was quoted $380! As for Mexican cars, I'm afraid to think what they would cost to get to Canada.
Aha, I didn't realize you were from Canada. OP is from the USA. :)
Carnut1420
Carnut1420 New Reader
1/2/10 3:21 p.m.
That is cool!! I feel affection for, standard, stable, and good-looking! I don't have any work practice with this company before, do you just heard about it or have their services, what is your skill with them.
dupon registry
fornetti14
1/2/10 4:05 p.m.
Canoe
Turns out it was a broken clutch cable. I gave the cable end a good pull and found where it frayed and broke off.
Sounds like something may have fell down into the bell housing and messed up the throwout bearing.
I'll post up pics. later.
Carnut1420
1/3/10 2:35 p.m.
Thanks you!!! I LOVE the new selection!!! But I also concerned being familiar with it
dupon registry
Carnut1420
1/4/10 3:32 a.m.
Its really nice post.... I was searching this kind of posting ..... I just liked it.... Thanks....
dupon registry
Carnut1420
1/4/10 11:00 a.m.
This was the main cause I joined all those years ago. Thanks….Turns out it was a broken down grasp cable. I gave the cable end a good pull and found where it frayed and broke off.
dupon registry
Yyivi0KZGddXgJgbpOXWX8nN4JkID9F9gUYS55Ia9lEC06Bg4ehWPLZsnfLpbf25
