MrChaos
MrChaos GRM+ Memberand SuperDork
2/9/20 10:37 a.m.
sleepyhead the buffalo
2/9/20 10:52 a.m.
FYI, tweaked your title to combine it w/ Boxhead's.
I'll maybe have more substantial comments later.
Jumper K Balls (Trent)
Jumper K Balls (Trent) PowerDork
2/9/20 11:36 a.m.
That episode was exactly what I expected it to be. The next logical step.  My only complaint would be the green passivate.
Anyone have experience with that Toyota rear suspension?  The monoball bushings look exactly like the ones BMW E36's use in the rear. I'm curious about their dimensions. Part number 42210-14010.  Just hoping they are a bit smaller than the bmw pieces
2/9/20 1:13 p.m.
Indeed they are smaller!
maschinenbau
maschinenbau GRM+ Memberand SuperDork
2/9/20 2:06 p.m.
Interested in that DIY electroplating kit...although that green is ugly AF. I want that shiny zinc finish on some hardware.
The0retical
The0retical UberDork
2/9/20 2:34 p.m.
In reply to maschinenbau :
Caswell sells kits
_
_ Dork
2/9/20 2:49 p.m.
https://www.eastwood.com/ew-electroplating-system-tin-zinc.html?SRCCODE=PLA00020&gclid=EAIaIQobChMIv7zeyavF5wIVth6tBh13pQE_EAQYASABEgLy6vD_BwE
this looks like something that can be cobbled together very easily. The gloves, goggles, funnel, etc are all standard garage items. The electrolyte juice could be had from Gatorade or pedialyte. The Sadomasochist electrode device is just wires and a battery. Then you need what ever the heck "metal polish" is.
RossD
RossD MegaDork
2/9/20 2:53 p.m.
In reply to Jumper K Balls (Trent) :
What is a sphereical bearing?
Knurled.
2/9/20 4:54 p.m.
In reply to RossD :
It's like a rod end that presses into a bore, but that's not important right now.
Finally saw the episode.  One nitpick:  When you use poly bushes, you do not need to torque up the bolts at ride height.  The sleeves can rotate freely inside the poly, they are not like rubber bushes that are bonded to the rubber, leaving all range of motion limited by rubber flex and twist.
I'm also only slightly disappointed that they didn't make any "Andy did it" kind of jokes.
Ransom
Ransom GRM+ Memberand UltimaDork
2/9/20 4:59 p.m.
I had the same thought. I don't even mind the color all that much; I just can't imagine setting yourself up to have to replace dropped and lost nuts/bolts with stuff that's standard silver or gold, or have to blast, re-plate, re-color...
nderwater
nderwater UltimaDork
2/9/20 6:21 p.m.
In all of human history, no Mini Cooper has had so many man hours invested in getting it finished.
GIRTHQUAKE
GIRTHQUAKE HalfDork
2/9/20 6:42 p.m.
In reply to _ :
Yep! I think Hand Tool Rescue did a home electroplating rig for Nickel; aside from your containers, destenalized water and electrode you need strips of nickel and time.
stuart in mn
stuart in mn MegaDork
2/9/20 7:52 p.m.
Excellent video as always.  Considering how meticulous they've been on everything else, I was a little surprised they didn't take the time to re-weld and smooth out the lumpy factory welds on the crossmember.
Robbie
Robbie GRM+ Memberand MegaDork
2/9/20 10:20 p.m.
Holy balls. So much time. I wanted to curl up and cry when they were masking the already finished part to put some etch primer on the engineered surfaces...
I really like the green.
grover
grover GRM+ Memberand HalfDork
2/9/20 10:25 p.m.
In reply to Robbie :
That was insane. Green is no bueno. Gold would have been awesome.
maschinenbau
2/9/20 10:33 p.m.
In reply to stuart in mn :
Or all the rust pits after sandblasting. Still looks great though.
maschinenbau
2/10/20 7:50 a.m.
Interesting, that looks just like a G35/350Z rear shock mount bushing! Same dimensions except the Nissan one is for M12 bolt instead of M14
https://www.rockauto.com/en/moreinfo.php?pk=8163588&cc=1431956&jsn=336
FuzzWuzzy
FuzzWuzzy HalfDork
2/10/20 8:41 a.m.
Kinda wish they went with the black or a zinc instead of that green.
The0retical
2/10/20 8:45 a.m.
The green reminds me of zinc chromate primer that's really common in aerospace applications.
I'm indifferent to what color they chose, but personally I like seeing CAD plated hardware because it stands out better. I really liked the change of pace from the body work.
T.J.
T.J. MegaDork
2/10/20 9:22 a.m.
I thought the green was a nice nod to the green paint BMC used on their engines. I call it MOWOG green, but not sure what the actual name is.
If it were me, I'd gone with cad plated hardware though.
TurnerX19
TurnerX19 Dork
2/10/20 9:31 a.m.
In reply to T.J. :
Real cadmium plate is a no-go everywhere now for environmental reasons now. You can have zinc, or...Zinc if you don't want to pay for nickel.
T.J.
T.J. MegaDork
2/10/20 9:33 a.m.
In reply to TurnerX19 :
I didn't realize that. Is there a way to get a similar color?
NOHOME
NOHOME MegaDork
2/10/20 9:39 a.m.
Reminds me of the Youtube vid where they take some tool or household device that looks wrecked and restore it to brand new.
I love the before and after pics
bigdaddylee82
bigdaddylee82 UltraDork
2/10/20 9:42 a.m.
That green plating is similar to Tractor Supply's grade 5 SAE fasteners, and I've got bin fulls of them in the garage.  While I probably wouldn't have picked it myself, I guess I'm used to it and don't mind it so much.
2/10/20 11:49 a.m.
At this point it barely qualifies as as a Mini.
AvN7tFHSk5IgcvvY4JqLWBwcAZEfjufjo4G8u0S8DJ2K7jtKYFFWfIQRhPhvmakY
