SyntheticBlinkerFluid
11/5/14 11:26 p.m.
Just saw this on Bangshift, thought some folks here would find it interesting.
http://bangshift.com/general-news/new-products/sema-2014-rhs-offers-pro-elite-lt1-head-designed-retrofit-ls-blocks-best-worlds/
Flip06gt
Flip06gt New Reader
11/6/14 12:09 a.m.
Very interesting indeed.
novaderrik
novaderrik PowerDork
11/6/14 4:19 a.m.
the new LT1 is pretty much just an LS engine with direct injection and a few other upgrades, so what's revolutionary here?
mazdeuce
mazdeuce UberDork
11/6/14 5:29 a.m.
The LT1 heads are supposed to flow much better in NA applications.
Knurled
11/6/14 6:16 a.m.
novaderrik wrote: the new LT1 is pretty much just an LS engine with direct injection and a few other upgrades, so what's revolutionary here?
Vortec heads are just iron SBC heads, too.
gearheadE30
gearheadE30 New Reader
11/6/14 7:18 a.m.
Knurled wrote: Vortec heads are just iron SBC heads, too.
I wonder if if will end up being the next big thing since the vortecs... Sounds promising to me. I would imagine the head itself is basically an LS head with LT port/valvetrain/chamber geometry then? Bolt-in stuff is always nice.
Gearheadotaku
Gearheadotaku GRM+ Memberand PowerDork
11/6/14 7:31 a.m.
and I'll bet that one head costs more than a challenge car.
Will
Will SuperDork
11/6/14 8:21 a.m.
For a minute I forgot that there's a new LT1, and wondered why I'd want an old LT1 head for my LS1.
Now that I've figured that out: it mentions accessory drive compatibility, but what about intakes and headers? And are these really any better than the current aftermarket LSx heads?
jsquared
jsquared Reader
11/6/14 11:23 a.m.
I assume this would enable adapting a direct injection setup to an LSx shortblock? I've never shopped around for a HPFP or DI injectors, what's the cost difference from that idea and just ordering an LT1 crate engine?
81cpcamaro
81cpcamaro HalfDork
11/6/14 11:28 a.m.
I don't think it would allow for DI, LS block doesn't have the provisions for the DI pump which runs off the camshaft. Being there are plenty of very good LS heads out there, I would like to see some dyno tests to show if these heads are better or not.
Kenny_McCormic
Kenny_McCormic PowerDork
11/6/14 11:49 a.m.
The vortec heads were a big thing because they were cheap new, or practically free off an old pickup truck.
Knurled
11/6/14 12:03 p.m.
And they flowed like the dickens and had decent combustion chamber shapes.
The new LT1 has a heavily skeletonized intake pattern. From what I remember it looks more like a Mod motor than anything Chevy ever did.
novaderrik
11/6/14 1:31 p.m.
they are the only factory iron heads worth getting for a gen 1 small block... i have 2 sets, both on running engines..
also, this thread is about aftermarket heads- vortecs were stock production heads.. i wonder how these new heads compare to some of the bigger factory heads that GM has put on factory built engines?
HiTempguy
HiTempguy UberDork
11/6/14 1:38 p.m.
Kenny_McCormic wrote: The vortec heads were a big thing because they were cheap new, or practically free off an old pickup truck.
And these could be big if they are cheap enough. I doubt they will be grossly expensive (which is the good thing about oem heads)
Opti
Opti Reader
11/6/14 3:08 p.m.
If you have a big bore ls, you can just buy the l92s. They are hard to beat for the dollar to performance ratio. Unless these work on the 5.7s and other small bore LSs or outflow the L92 and are just as cheap I don't see them being worth it.
I believe they both flow a little over 310 cm intake and around 200 exhaust.
The only plus I see Is apparently you can get the lt1 head for a small bore on an l86 (which flow about the same), and I believe the L92 only works on the big bore
11/6/14 6:14 p.m.
The fact that Chevy keeps recycling engine names has me going " Why the hell are they adapting a Gen II head to fit an LS motor?" They need to stop this.
Knurled
11/7/14 5:39 a.m.
Appleseed wrote: The fact that Chevy keeps recycling engine names has me going " Why the hell are they adapting a Gen II head to fit an LS motor?" They need to stop this.
You'd think that they would keep regressing and go to LRn engines.
81cpcamaro
81cpcamaro HalfDork
11/7/14 8:47 a.m.
GM loves to recycle engine codes (and all option codes, like Z06 and others). LT is on its 3rd round, LS is on its 2nd. So maybe the next engine redesign will be LS again? Or will they go back to codes like L82? Time will tell.
11/7/14 11:16 a.m.
Dodge is make big waves with their Hellcat engine. Hoping for the day that engine names, proper, comeback.
novaderrik
11/7/14 11:34 a.m.
there's only so many numbers and letters, and "L" is the internal option code for "engine".. they might as well keep using the same codes for the good stuff that they always have..
Knurled
11/7/14 12:25 p.m.
Don't forget the hyphen... an LS-6 and an LS6 are way different, same for LS7 vs. LS-7.
I'd rather have the hyphen, myself...
Opti
Opti Reader
11/7/14 4:09 p.m.
Same with cars. ZR1s and ZR-1s.
They are already using codes like L82. Normally its on the boring stuff like in trucks, they have the L86, L92, L76. Im sure the engine designations in the vette and other performance cars are marketing. LT1, LS3 sounds better than L92.
Llr6teypGUx5dB9Ezerb5AkuW9Xu743FSPZlpolE6aIO7bJGWzThoxOoyerPV3NW
