Grtechguy
Grtechguy SuperDork
3/11/09 6:55 a.m.
No specific reason in mind.....
But can a modern VW/Audi TDI engine be attached easily to a rwd manual tranny?
John Brown
3/11/09 7:08 a.m.
If you have the ability to machine a bellhousing adapter, sure.
The Passat (A4) TDi engine sits North - South so there would be no water pump / accessory drive issues, The wiring harness is pretty simple, but the computer will freak out one the CAN-BUS returns an incomplete circuit.
I say look into a Miata 6 speed and build an adapter.
RossD
RossD New Reader
3/11/09 7:13 a.m.
Or try to move the transaxle to the rear like the porsche 944, or just use the porsche parts and get an adapter from kennedy adapters. Hey, wait. That might actually work...
MrJoshua
MrJoshua SuperDork
3/11/09 7:51 a.m.
Search www.locostusa.com I think it has been done.
cghstang
cghstang New Reader
3/11/09 7:56 a.m.
Adapters for suzuki and toyota transmissions.
http://www.acmeadapters.com/index.php
ignorant
ignorant SuperDork
3/11/09 8:04 a.m.
cghstang wrote: Adapters for suzuki and toyota transmissions. http://www.acmeadapters.com/index.php
Yes they can in toyota trucks and suzukis, All the time.
The question we should ask is, do you have a welder?
Grtechguy
Grtechguy SuperDork
3/11/09 8:05 a.m.
Yep... Stick, Wire, and Gas :)
ignorant
ignorant SuperDork
3/11/09 8:16 a.m.
Grtechguy wrote: The question we should ask is, do you have a welder? Yep... Stick, Wire, and Gas :)
Then the answer is.. YES!
Travis_K
Travis_K HalfDork
3/11/09 8:42 a.m.
Bolting it in shoudlnt be hard, getting all of the wiring right, the drive by wire throttle, etc will be more complicated.
ignorant
ignorant SuperDork
3/11/09 9:16 a.m.
Been done. http://forums.tdiclub.com/showthread.php?t=212459
http://www.cs.yale.edu/homes/jag/vw/engine/tdiswap/tdiswap.html
http://www.toyotadiesel.com/forums/showthread.php?t=186
Geez I want to do one.
mistanfo
mistanfo Dork
3/11/09 9:17 a.m.
I think that a Locost with the TDI would be sweet. Horsepower levels near the original, with double the torque!
mw
mw Reader
3/11/09 10:22 a.m.
mistanfo wrote: I think that a Locost with the TDI would be sweet. Horsepower levels near the original, with double the torque!
And likely much more weight!
Personally for a locost, I would want a suzuki swift twincam bolted to a samurai trans mission.
Nashco
Nashco SuperDork
3/11/09 12:47 p.m.
I, too, have thought a first gen 4Runner with a TDI would be cool...but parts prices for the TDIs are just ridiculous. For the price of a TDI with all the bits and pieces needed for a swap, you can do an LSx based engine swap and have a touch less mileage and way more fun potential. A pre-TDI VW diesel running on veggie oil would be cool, but a bit gutless and noisy for my tastes.
Bryce
Ian F
Ian F Reader
3/11/09 1:01 p.m.
Yep... these have been around... makes the most sense to the TDI fanatics... and you can get a pretty good amount of power out of a TDI for a reasonably amount of money... I know a ugy who is in the planning stages of a TDI swap into a Fiero... Not his, personally (customer/club memeber car), but considering he owns a German car repair shop and recently completed a VR6 Fiero swap, a TDI swap shouldn't be difficult for him. Through the VR6 swap, he has already figured out much of the ECU compatibility issues.
I'm guessing the hold up has been the cost... as Bryce mentioned... used/wrecked TDI's aren't cheap... whereas running MkIV VR6 cars comparitively grow on trees...
3/11/09 1:01 p.m.
I think a locost with the TDI would make a great commuter car.. imagine the fun AND miliage?
Ian F
Ian F Reader
3/11/09 1:21 p.m.
If you own a TDI, you may think differently... I know I do...
Grtechguy
Grtechguy SuperDork
3/11/09 3:22 p.m.
well, can the TDI be tweaked as much as say..... a Cummins or a Powerstroke?
John Brown
3/11/09 3:56 p.m.
Yes*
The gains are not as high unless you are comparing % vs stock improvement.
A 5.9L making 400hp and 1200ft lb versus a 1.9L making 250hp and 500ft lb in modified form you can see the TDi is making more out of the fuel it is consuming.
ignorant
ignorant SuperDork
3/11/09 5:09 p.m.
Grtechguy wrote: well, can the TDI be tweaked as much as say..... a Cummins or a Powerstroke?
does a bear poop in the woods?
Where is the link to the new beetle with 400+ ft-lb of torque
ignorant
ignorant SuperDork
3/11/09 5:10 p.m.
John Brown wrote: Yes* The gains are not as high unless you are comparing % vs stock improvement. A 5.9L making 400hp and 1200ft lb versus a 1.9L making 250hp and 500ft lb in modified form you can see the TDi is making more out of the fuel it is consuming.
to make 1200 ftlb of torque a 5.9 would be pushing 600+ horse power.
Tim Baxter
Tim Baxter Online Editor
3/11/09 5:30 p.m.
does a bear poop in the woods? Where is the link to the new beetle with 400+ ft-lb of torque
http://grassrootsmotorsports.com/articles/your-mileage-may-vary/
rLETcaP8bp62LmDuG2sfiEchmEQ6MnJmVOQEDBtBgYLYnK25qHLcDRFIkdcVtMcC
