Feedyurhed
Feedyurhed Reader
11/27/08 3:28 p.m.
Who would have thought a national holiday is more important than talking about cars? Winter just started a few weeks ago here and I am already itching for a Spring. I need my car fix.
wherethefmi2000
wherethefmi2000 Reader
11/27/08 3:34 p.m.
well I guess everyone is getting fat on turduckens
Keith
11/27/08 6:33 p.m.
I'm pulling the engine out of the MG so I can start measuring things for the LS1. The national holiday is so I can work on cars, isn't it?
AngryCorvair
AngryCorvair GRM+ Memberand Dork
11/27/08 9:04 p.m.
i drove the V8 944 around the neighborhood today. we were out of town for a few days, and it was cold enough to freeze the water in the hoses, so i knew i had to thaw it out before it got any worse. got it fired up, but the water in the water pump was frozen so it wouldn't spin, and the belt was screaming loud. so i shut it down and removed the belt, then fired it up again. let it run until the intake felt good and hot, then shut it down and waited for the heat to soak through the cooling system. one of the threaded plugs in the block was leaking, and the hose from the rad to the water pump was leaking and looked like it had been pushed apart by the expansion of the water freezing. so i put the hose back together, then dumped a bottle of "K-Seal" into the expansion tank, and chased it with 1.5 gallons of prestone. started up the engine again and let it run for about 10 minutes. just like it said on the label, the leak stopped within three minutes.
is that car talk enough for a holiday?
aussiesmg
aussiesmg HalfDork
11/27/08 10:10 p.m.
I can't reach the laptop after eating so much turduckens, I think my lap has gone for good
Feedyurhed
Feedyurhed Reader
11/27/08 10:19 p.m.
AngryCorvair wrote: i drove the V8 944 around the neighborhood today. we were out of town for a few days, and it was cold enough to freeze the water in the hoses, so i knew i had to thaw it out before it got any worse. got it fired up, but the water in the water pump was frozen so it wouldn't spin, and the belt was screaming loud. so i shut it down and removed the belt, then fired it up again. let it run until the intake felt good and hot, then shut it down and waited for the heat to soak through the cooling system. one of the threaded plugs in the block was leaking, and the hose from the rad to the water pump was leaking and looked like it had been pushed apart by the expansion of the water freezing. so i put the hose back together, then dumped a bottle of "K-Seal" into the expansion tank, and chased it with 1.5 gallons of prestone. started up the engine again and let it run for about 10 minutes. just like it said on the label, the leak stopped within three minutes. is that car talk enough for a holiday?
Sweet. I am feeling better now thanks.
DILYSI Dave
DILYSI Dave SuperDork
11/27/08 10:52 p.m.
You know - they make this tasty green liquid that fixes that problem.
dansxr2
dansxr2 New Reader
11/27/08 11:56 p.m.
pulled the trans pan on the Corrado to see whats up with the transmission, I think there is a short in the grounds. I'll have it checked out this week.
AngryCorvair
11/28/08 10:11 a.m.
DILYSI Dave wrote:
AngryCorvair wrote: and chased it with 1.5 gallons of prestone. started up the engine again and let it run for about 10 minutes. just like it said on the label, the leak stopped within three minutes.
bolded for DILYSI Dave's reading comprehension. i had the cooling system filled with water in case i dumped on the track at the challenge, then kinda forgot about it. no more worries, as the 1.5 gallons of prestone should give me arctic protection.
neon4891
neon4891 Dork
11/28/08 10:16 a.m.
i was looking at an accord I will probly get, as my neon has passed the point of Daily drivability
DILYSI Dave
11/28/08 10:22 a.m.
I read it. It just seems like adding prestone to an already frozen motor is like putting a condom on after she's pregnant.
Grtechguy
Grtechguy SuperDork
11/28/08 10:25 a.m.
tryptophan effect kicking in strong :D
Tim Baxter
Tim Baxter Online Editor
11/28/08 10:30 a.m.
It's always quiet Thanksgiving and the day after. That's why we rolled out the new stuff this morning!
Grtechguy
Grtechguy SuperDork
11/28/08 11:10 a.m.
noticed quite a few things.
preview of recent threads
the facebook/digg/yahoo buttons.
I'm sure there's more
GameboyRMH GRM+ Memberand SuperDork
11/28/08 11:15 a.m.
Yeah I think activity has hit an all-time low over the last few hours.
11/28/08 11:45 a.m.
We were at the Turkey Rod Run yesterday (big car show at Daytona speedway).
JmfnB
JmfnB GRM+ Memberand SuperDork
11/28/08 11:56 a.m.
Tanner and I played with Play-Dough and the baby made a poo that was the EXACT same color... inspiration!
AngryCorvair
11/28/08 2:07 p.m.
true. i was lucky that temps weren't consistently below freezing while i was ignoring the car. no damage done.
FWIW, i think the new 3-dimensional smilies are ghey.
wherethefmi2000
11/28/08 3:25 p.m.
I know why there's no activity, no one is at work
Tim Baxter
11/28/08 3:30 p.m.
Basically, yeah. On holidays, and holiday weekends, traffic is usually about what it is on a weekend. Yesterday, for example, had almost the exact same traffic as a typical Saturday.
dean1484
dean1484 GRM+ Memberand HalfDork
11/28/08 4:41 p.m.
ummmmmmm Pie is good.. . .
O Wait this is not the food site.. ..
I have been messing with my megajolt cam triggered edis 924s project. I am pondering if I should try to use the WB02 0-5volt output to the aux port adn use it to retard timing if is goes to lean say something over 14 or so and it would drop timing by 3 deg. Then there is the period it is effect. I am wondering what it would do to throttle response as you would be lean on deceleration causing the timing to retard but getting on it would then delete it and put you back to the proper bin no the timing table.
Now back to pie.. . . . We have apple and pumpkin (not squash) and a cherry pie. I also made 3 turkey pot pies with the left overs. two standard and one with the Frenches onions as the top crust (think been casserole) The whole house is smelling better then yesterday.
My doc said be good on thanksgiving but he did not say a thing about the day after.
bigwrench
bigwrench New Reader
11/28/08 5:27 p.m.
Seems to have picked up!!! :)
o2PbJAYLjKwIr5zDTNVMaymvq3Lgz8iRRsyI8d1o8gETkdXiXozxDNmTCBk15zjp
