bonylad
bonylad GRM+ Memberand HalfDork
10/20/21 6:56 a.m.
Hey there, as some may know the S10 has a 305 swapped in and it runs great. I cant be sure when this developed but it did develop a noise.  Here is the setup.
1. Warm or cold engine
2. On a hard accel the engine picks up and at some point seems to lose ass until you let off a little bit
3. If you power through it and go back into it, once you let off you hear a noise from the passenger side near the firewall
4. The noise sounds like this. Say you have a container thats under vacuum, and you go prying on it. Say you crack the corner a little bit and it makes that squeaking/wooshing noise.  Thats the best way I can describe it.
Truck runs fine. I feel the bogging is a spring issue (too weak) for the secondaries, I also want to up the pressure to around 7 psi from the current 6.5. I also want to tweak the timing and give it a once over.
The noise makes me feel like its a fuel issue, and I am hearing the bowls running dry? Which I cant see happening as it continues to drive fine after. Leading me to a intake manifold leak? Thoughts?
Thanks!
Floating Doc (Forum Supporter) GRM+ Memberand PowerDork
10/20/21 7:08 a.m.
I think that if it sounds like a vacuum leak, start there.
Toyman01 + Sized and
Toyman01 + Sized and GRM+ Memberand MegaDork
10/20/21 7:15 a.m.
Vacuum canister failure? Vacuum solenoid in the AC system failing?
Sometimes at WOT, the HVAC solenoids will relax against the spring due to a lack of vacuum. As soon as the throttle closes they pull back. You may be hearing them move.
Sounds like it's leaning out as well.
bonylad
10/20/21 8:09 a.m.
The truck has no vac cannister, no HVAC at all. System was gutted from the front to the back - nothing at all in the dash not even the ducting.
Im leaning (see what I did there) towards the intake manifold leaking. I will go back and make sure all bolts are tight and regroup.
Will update!
10/20/21 8:13 a.m.
Vac modulator on trans?
10/20/21 8:21 a.m.
Video would be helpful
bonylad
10/20/21 9:04 a.m.
It doesnt have one AFAIK
bonylad
10/20/21 9:04 a.m.
I will try to make that happen!
bonylad
10/20/21 10:16 a.m.
Quick video uploaded as requested.
APEowner
10/20/21 11:28 a.m.
That sounds like a vacuum leak to me.
1SlowVW
1SlowVW HalfDork
10/20/21 6:50 p.m.
Maybe brake booster ?
Curtis73 (Forum Supporter)
10/20/21 8:08 p.m.
It's a rare condition....
Wait for it...
Throttle blades closing.
Seriously.  That's what the air sounds like as the velocity increases while you cut off the air.  I think you just may have a vacuum hose under there left over from something.
bonylad
10/21/21 8:40 a.m.
Wait for it...
I chuckled. That was perfect! Will look and see. I didn't see anything earlier nor did it act up when running and I sprayed carb cleaner. It did burst into flames though. That was fun. Apparently some wire I no longer use wasn't terminated right and with the fumes and me spraying. Whoosh!
B4xEVu0m2gV5dWdu8LnBjG5lan66JDsPssQfnJM50Eqi7m9iHNUNDbpqNlwddelV
