ScottyB said:
traction boards. you can get anything decent for under $200 on amazon.
check to make sure you have sufficiently strong recovery points on your vehicles. stock tie-down hooks are probably not safe long term.
get some soft shackles (if your recovery point is smooth enough) and a kinetic rope if its in the budget. make sure to check the working load limit vs the breaking strength of your shackles so you understand how much weight they're really designed to take in a normal pull.
JRGunfighter_John said:
Matt's Off-road Recovery on YouTube pulls much larger vehicles out of he super soft Utah sand with a Jeep Cherokee. Amazing what inertia can do.
you're not kidding. fascinating to see how he gets some of those huge pickups out in an otherwise fairly tame looking XJ. made me a believer in Yankum ropes.
looks fairly tame, but almost nothing underneath that XJ is stock. I think it's locked Dana 60 rear end, locked Dana 44 front end, heavy reinforcements. It's set up for heavy hitting like that (which actually somewhat limits its suspension travel/flex). But yeah, as far as engine and transmission go it's fairly stock.
I have definitely watched 100% of Matt's videos since I started following him last year.....and learned a good bit of my own off-roading knowledge from watching them!
My take on a few things:
- kinetic rope is awesome, but if you don't plan to use it A LOT, there's no real point. A snatch strap is a lot cheaper and takes up far less space, and will do the job if you only "occasionally" wheel. Kinetic rope is mostly for guys who do a high amount of heavy recoveries (like Matt, and more of the hardcore guys). If you're just going to do some sand trails with friends here and there, just go get a regular snatch strap (note: not a regular tow strap....) Or, if you're a baller, kinetic rope is great. But good kinetic ropes are very pricey.
- I just picked up some X-Bull traction boards (Generation 2). These things are really beefy and are pretty highly rated by a number of guys I know who are serious overlanders who don't sound like they can justify the much higher prices of a few of the marquee brands. You can get them for under $100 on Amazon. Look for the "new" version ones., which are much beefier than the originals.
- Good tires with good tread, air down, carry a good compressor to air back up (I have a mid-range Viair that can get my 31's from 15psi back up to 30+ in about 1 minute per tire.). Little cigarette-lighter-power auto stor compressors will take FOREVER. But seriously, the best thing you can do to NOT get stuck is to be aired down sufficiently. For sand, seems that most guys on A/T tires like it around 15psi. I tend to run closer to 20 in the Raider, but it's pretty lightweight compared to most.
- Yes, a shovel. Fold-up shovels are cool, but if you have space for a full-size shovel it makes life much easier if you have to dig. Digging on your knees sucks.
- WInch is fine, but if you're in sand without anything to hook to, won't do much good. Also in sand, more weight carried = more chance of getting stuck. If you're with another capable 4x4, there's no real reason he can't get you out of any stuck spot without a winch, IMO.
side note: what are you driving?
