oldtin
oldtin SuperDork
10/19/12 11:35 a.m.
I need a smallish - 1qt minimum rectangular oil catch can for the TR4. I'm not finding much so thinking of making one up from some aluminum. May seem dumb, but does anything like baffles go inside? Was thinking it needs a breather/ filter, intake bung and return line bung. Anything else?
EvanB
EvanB GRM+ Memberand PowerDork
10/19/12 11:38 a.m.
You can fill it with steel wool to act as a baffle.
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
10/19/12 11:38 a.m.
Baffles are good. You're pretty much on the right track otherwise.
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
10/19/12 1:26 p.m.
Don't use steel wool--it fragments too easily. Use stainless "scrubby" material like this:
http://www.kitchenworksinc.com/Stainless-Steel-Scrubby-Jumbo__970878.aspx?gclid=CLPexvrZjbMCFRQcnAodG0oAFw
For a good starting point, try a water bottle like this: http://www.newegg.com/Product/Product.aspx?Item=9SIA04005S1396&nm_mc=KNC-GoogleMKP&cm_mmc=KNC-GoogleMKP--pla--NA-_-NA
evildky
evildky Dork
10/19/12 2:23 p.m.
or use a used reciever drier from any old a/c system, free aluminum cylinder and already has a couple of bungs
donalson
donalson PowerDork
10/19/12 4:25 p.m.
this is more or less what Per is talking about... http://www.aaronreedbaker.com/oil.html
note you don't need the clear hose (or technically even the drain as you could just pour it out the top from time to time)... but his is a nice usable one... some spray paint would clean it up a lot
ht72esghz5vvekDlhlhZXDzjtQV5hW9ZrGckAB9GRgzW53W74bGwrVltsCnzF28P
