Fletch1
Fletch1 Reader
11/24/10 3:15 p.m.
My 2004 Civic (1.7L) is leaking oil from the bottom and from the top. I'm sure to check the drain bolt and filter when I get home (duh). There is oil on the oil filler cap and some on the valve cover. I checked it and the level was right at the top line. I accidentally got 5w30 instead of 5w20 this time. I haven't looked at it yet, but I don't know why there is oil on the cap and valve cover. I've owned it since new(89k now) and done most of the oil changes with 5w20 myself and no problems. I didn't know if the change in oil would cause this or not.
Toyman01
Toyman01 GRM+ Memberand SuperDork
11/24/10 3:23 p.m.
I would check the PCV valve if so equip. Probably stopped up and not creating a vacuum on the crankcase. It will make them leak like a sieve if they are bad.
iceracer
iceracer Dork
11/24/10 5:40 p.m.
As toyman said. Difference in the oil is not causing your problem. It won't hurt to run it.
iMru0W5fH8R7fwXO5BrclZ8G0VOk0Oij7RGUyqLOU2ZyA79mzJXDPDDSzWsRGtuR
