Taiden
Taiden SuperDork
3/24/12 1:41 p.m.
Any reason to replace both calipers at the same time, or can I just replace the one that is causing issues?
Streetwiseguy SuperDork
3/24/12 1:46 p.m.
No particular reason to change the good one, other than the fact that it is likely the same age as the one that failed.
Ranger50
Ranger50 SuperDork
3/24/12 1:49 p.m.
I've only ever replaced the one that is "broken".
ValuePack
ValuePack Dork
3/24/12 1:55 p.m.
I've replaced a pair on something I intended to keep forever, but it's likely just a waste of money.
z31maniac
z31maniac UberDork
3/24/12 2:13 p.m.
Rebuild the one that is sticking? Rebuild both just so they both are fresh?
aussiesmg
aussiesmg PowerDork
3/24/12 2:31 p.m.
Cost vs rebuild, my RX7 calipers were nearly $600 for 4 rebuilt, and $6 for 4 rebuild kits
integraguy
integraguy UltraDork
3/24/12 6:22 p.m.
I have no idea why, but I had a 280Z that had a sticking caliper. I only ever rebuilt the sticking one as, for some reason (perhaps bad rebuild?) it was the only one that ever needed it. I also owned a G20 that did the same thing. Never had that problem on the 3 Hondas and 1 Acura I've owned.
Derick Freese
Derick Freese Dork
3/24/12 6:56 p.m.
I've always rebuilt them in pairs, but the one time I had to replace one, I only replaced that one. I did rebuild the other caliper on the axle.
akamcfly
akamcfly Reader
3/24/12 7:01 p.m.
aussiesmg wrote: Cost vs rebuild, my RX7 calipers were nearly $600 for 4 rebuilt, and $6 for 4 rebuild kits
Cavalier - it was $8 more for a complete caliper without pads than it was for a new pair of bolts.
Taiden
Taiden SuperDork
3/24/12 7:03 p.m.
Will a rebuild kit take care of a sticking caliper?
Is it just a swollen main seal?
The slides move silky smooth.
Derick Freese
Derick Freese Dork
3/24/12 7:05 p.m.
You probably have a worn cylinder bore or have crap that's keeping the piston from moving. I'd bet that you can clean it up and do a rebuild and get a lot more service from the caliper.
hotrodlarry
hotrodlarry HalfDork
3/24/12 9:20 p.m.
check the rubber hoses too.
z31maniac
z31maniac UberDork
3/24/12 9:25 p.m.
Likely the sliding pin or the piston are rusted.
I sent my calipers to a buddy to rebuild, the sliding pin had rusted/seized and broke his vice, then he had to drill it out.
Taiden, I was thinking you drive an e30? If so, rebuilt calipers are cheap if you didn't want to futz with it.
Taiden
Taiden SuperDork
3/24/12 11:16 p.m.
It's the e28 I just picked up. The e30 is all good at the moment.
Taiden
Taiden SuperDork
3/25/12 8:19 a.m.
I ended up buying two caliper rebuild kits from rock auto. We'll see if it's more of a headache than it's worth.
I have an atlas benchtop lathe that im borrowing from a friend. I'm thinking of turning off the rust on the pistons. I wouldn't turn it to a lesser dimension than the good part of the piston, of course. Bad idea?
iceracer
iceracer SuperDork
3/25/12 11:11 a.m.
Bad idea ! Just clean off the surface rust. Fine sandpaper works fine. If the piston is pitted, time to replace. Rust and or tired piston seal are the causes of the piston sticking.
Taiden
Taiden SuperDork
3/25/12 12:21 p.m.
Bad idea! Got it.
ba1LGhQ0fDxz0wIKFvr1iGEuBccQByRDBmvJmZyr1tK1Bpml9aGEpTewKeP6aywM
