RenoSolo
RenoSolo None
8/1/13 9:20 p.m.
I remember GRM mentioning a new, very useful One Man Bleeding unit in one of their articles, but damned if I can find it in the back issues I have. Does anyone remember it? (It was only a few months ago.)
Slippery
Slippery GRM+ Memberand Reader
8/1/13 9:26 p.m.
I know of this one
http://www.motiveproducts.com/
RenoSolo
RenoSolo New Reader
8/1/13 9:28 p.m.
That's not it, I remember the price was $29.95 and it wasn't a power bleeder, but GRM raved about it.
turboswede
turboswede GRM+ Memberand PowerDork
8/1/13 9:31 p.m.
speedbleeders?
Also you can simply put a hose from the bleed nipple into a bottle with some fresh fluid in it.
JohnyHachi6
JohnyHachi6 HalfDork
8/1/13 10:01 p.m.
I don't know about it being 29.95, but they raved about this one in an issue about a year ago:
Phoenix Systems reverse bleeder
bgkast
bgkast GRM+ Memberand HalfDork
8/1/13 10:20 p.m.
Small garden sprayer+hose barb+old brake reservoir cap=grassroots one man bleeder
8/1/13 10:29 p.m.
Gravity = super grassroots one man bleeder.
motomoron
motomoron Dork
8/1/13 10:33 p.m.
A Motive Power Bleeder is one of the best tool purchases I've ever made, and I own every tool known to man. Seriously.
The same one fits my e36 M3 track rat and the Radical, and I can bleed all 4 corners, perfectly, in about 10 minutes.
They're like $50, and totally worth it.
Kenny_McCormic
Kenny_McCormic SuperDork
8/1/13 10:42 p.m.
You can get the tough ones close with gravity and then reverse bleed with a bigass syringe.
SkinnyG
SkinnyG HalfDork
8/1/13 11:07 p.m.
I use this, with a 25' length of vacuum hose from the unused spigot to a vacuum port on the running engine.
novaderrik
novaderrik UberDork
8/1/13 11:49 p.m.
Keith Tanner wrote: Gravity = super grassroots one man bleeder.
yeah, but it's more fun to over think it and throw money at it..
bgkast
8/1/13 11:54 p.m.
In reply to novaderrik:
You guys must have magic brakes, I always need flow velocity to get the air bubbles out of the high parts of the lines.
Warren v
Warren v Reader
8/2/13 12:43 a.m.
Yeah, gravity won't work in many cases, especially on ABS cars.
jere
jere HalfDork
8/2/13 1:49 a.m.
bgkast wrote: Small garden sprayer+hose barb+old brake reservoir cap=grassroots one man bleeder
Agreed, mine cost all of $15 with some left over tubing. It's pretty cool I can bleed calipers with the nipple upside down on the caliper (ie two left calipers or just reversed), and can do the bleed order completely wrong
failboat
failboat SuperDork
8/2/13 5:48 a.m.
whoa. i have a garden sprayer and the spray handle is broke but the tank is fine. i guess I need to start shopping for extra brake reservoir caps. its probably easier than dragging the wife out to the garage to help me.
cdowd
cdowd Reader
8/2/13 8:03 a.m.
I have used the motive one for my BMW and swmbo's Saab. It has worked very well. I also don't have to get irratated when my wife or kids don't do it the way I want them to.
Dr. Hess
Dr. Hess UltimaDork
8/2/13 9:07 a.m.
Clear plastic tubing and an olive jar. Cheap one man bleeder.
HappyAndy
HappyAndy SuperDork
8/2/13 10:09 a.m.
JohnyHachi6 wrote: I don't know about it being 29.95, but they raved about this one in an issue about a year ago: Phoenix Systems reverse bleeder
I have a homebrewed version of that. Similar to this, but with a clear bottle.
GameboyRMH GRM+ Memberand UltimaDork
8/2/13 10:10 a.m.
Speed bleeders are like 50c each and they're the easiest solution once installed.
Cotton
Cotton SuperDork
8/2/13 11:16 a.m.
GameboyRMH wrote: Speed bleeders are like 50c each and they're the easiest solution once installed.
I always end up forgetting which cars have them. I have both the motive and mityvac, I like both, but use the mityvac the most
carczar_84
carczar_84 New Reader
8/2/13 1:03 p.m.
Here is what I used, with a small length of clear tubing.
Super cheap, super simple, almost too easy!!
McMaster Carr - 6079T58
http://www.mcmaster.com/#catalog/119/497/=nw46rf
Cone_Junky
Cone_Junky Dork
8/2/13 1:22 p.m.
turboswede wrote: speedbleeders? Also you can simply put a hose from the bleed nipple into a bottle with some fresh fluid in it.
I have been using a Gatorade bottle and a silicone vacuum hose for decades as a one man bleeder. As long as the end of the hose is submerged in fluid you will never get air back into the system.
This is the deluxe model with custom hanger (literally).
novaderrik
novaderrik UberDork
8/2/13 5:51 p.m.
bgkast wrote: In reply to novaderrik: You guys must have magic brakes, I always need flow velocity to get the air bubbles out of the high parts of the lines.
must be... i've always been able to just use gravity with a slight assist from the master cylinder to get things moving..
Slippery
8/2/13 6:53 p.m.
I usually use gravity, the key is to be patient as it might take an hour or more until new fluid starts coming out.
JohnyHachi6
8/2/13 7:13 p.m.
In reply to Slippery:
You also need to be sure the car is on flat ground. I was doing this a few months ago in my really bumpy/not level driveway. After waiting for a while with no luck I realized that the caliper I was working on was the same height as the MC. Gravity is not gonna help much in that situation. Easily rectified though.
PVK139tjHaPpBObjSjYm7ivOBjDvVMxiJ3RuwaPwXt6mzfCAhs6ZW9MmpjxHmncj
