Caperix
Caperix Reader
1/29/23 8:00 a.m.
My 91 e30 has developed a warm miss that is driving me crazy trying to track down.  The lack of faults & slow data transfer of the 1.3 dme is not leading me anywhere.  I am thinking its time to scope some signals & see what is dropping out.  There are a number of low priced oscilloscopes on the market now,  but how good are they?  Does anyone have any experience with one brand over a other?
wae
wae PowerDork
1/29/23 8:11 a.m.
I've got a Hantek USB unit that seems to work okay.  Having never used anything else, I have nothing to compare it to, but I have used it to do things like check injectors, watch crank and cam sensors, and do relative compression tests.
Caperix
Caperix Reader
1/29/23 8:32 a.m.
Is that the 8 channel one I see on Amazon?  I have looked at that, it seems to get ok reviews, mainly due to software.  Did you have any issues getting it loaded?  I am hoping crank sensor, fuel injectors & secondary ignition measurements will give me a better idea of what is going on.  It sounds like this should do that.
wae
wae PowerDork
1/29/23 12:52 p.m.
In reply to Caperix :
More than likely it is   I didn't really have any trouble getting the software loaded, but it has zero instructions so I had to do a bunch of YouTube watching to sort of figure it out.
1/29/23 6:14 p.m.
Came here to recommend these types of cheap USB units.
I got an old Tektronix 100mHz scope for less than $100 on FB Marketplace.  Accurate and bulletproof.
frenchyd
frenchyd MegaDork
1/29/23 8:52 p.m.
In reply to wae :
Sorry I can answer your question but back in 1961  I worked at a corner gas station and we had this wall of instruments including an  oscilloscope.  I found it absolutely facinating  wish I could find one of those to put in my Man Cave.
 Sorry to disturb.  Return to your regular message.
Caperix
Caperix Reader
2/4/23 2:12 p.m.
Purchased a hantek 8 channel USB scope box to try.  I think it worked good enough to find my issue. My crank sensor signal is doing strange things when the issue occurs.
ghI0u7JUN3KHlA6wyYgso8upLkx1QE3X8gATf3B6jkKF5UmkeP0ZWmbq422ZpLtA
