Will
Will SuperDork
7/26/14 3:58 p.m.
When the plastic tool bends as you torque down the pressure plate, it makes it really, really hard to align a dual-disc clutch and install the trans. Next time I'll have a spare input shaft handy.
Just an FYI.
LS1/T56/Ram dual disc street, if anyone cares.
dean1484
dean1484 GRM+ Memberand UltimaDork
7/26/14 4:13 p.m.
Quick tip on this one.
Using a 3/8" socket extension (6" long works well) get a 3/8" socket that fits in to the pilot bearing hole. Then get a 1/2 " socket that fits the hole in the friction plate. Both sockets should be a close fit but best to error on the side of a hair loose so you can get them out. Now take the 1/2 inch socket and slide it on to the extension and then put the 3/8" socket on the extension and you now have a makeshift clutch alignment tool.
I have done this in a pinch several times with very good results.
pjbgravely
pjbgravely Reader
7/26/14 5:55 p.m.
I have an old clutch alignment tool with metal rods and attachments. Hopefully it will fit for my next clutch replacement. The last one I had to hook up the clutch cable and have someone press it while I wiggled the transmission in. The plastic alignment tool failed.
Dr. Hess
Dr. Hess MegaDork
7/26/14 7:18 p.m.
We pulled a AC VW trans at a campground once and replaced a TOB and pilot bushing. I aligned the clutch with a tree branch. I did hack on it some with my hatchet first, you know, to get it round. Trans stabbed right in.
LopRacer
LopRacer HalfDork
7/26/14 7:40 p.m.
I have somewhere one of those nifty universal clutch line up tools made by Snap On. The one with all the different size ends for the pilot bearing and a sliding cone to line up the plate with. I bought it from a pawn shop years ago. I have only had to use it a few times but it does a great job.
Knurled
7/27/14 8:26 a.m.
The plastic tools generally have too much tolerance to to a good job of lining up the clutch unless you are anal retentive about eyeballing it. My favorite "tool" is a 3/8" or 1/2" drive extension that is built up with rounds of electrical tape.
bentwrench
bentwrench Reader
7/27/14 12:58 p.m.
Another observation is that you should not tighten up one side. You should sneak up on it, easing the pressure plate down, keeping the stack flat.
Even if you had a steel pilot tool cranking down one side is going to skew the stack and wedge the tool.
wspohn
wspohn HalfDork
7/28/14 10:24 a.m.
I'd have thought that most people that have been doing their own wrenching for a few years would have a spare input shaft out of a thrashed gearbox - there is really nothing better than that as a pilot shaft.
Will
Will SuperDork
7/28/14 1:10 p.m.
In reply to wspohn:
I've never killed a transmission before, so I didn't have one handy, and T56 input shafts are kind of pricy. The only clutch I installed previous to this went in fine with the plastic tool, so I never considered it wouldn't this time around.
Streetwiseguy UberDork
7/28/14 1:45 p.m.
If you bent the tool, you were doing something wrong, I think. You must have applied too much torque on one side or the other as you tightened it down.
A steel shaft is a wonderful thing, though its hard to collect enough for all applications. I still have both old redblock Volvo input shafts in my box somewhere.
wOUUWij7zSWU9u5bWO9YeB51jHh2MSWr2LnHH0Av1b1V3Z6nkrsAi6rBtnq3hYhp
