saruken
saruken Reader
11/16/20 9:41 a.m.
Like the title says, the previous owner of my '83 Civic hatch cut off the exhaust at the manifold:
It's all one piece up to the header, and the pipe has some complicated bends to it.
I want to do all the work on this car myself, but I don't have a welder. Is this when I need to buy one? Should I try to track down new parts? Is there some kind of magic clamp/joint I could use here?
Thanks all. I've never tried to do any exhaust work myself before.
84FSP
84FSP UltraDork
11/16/20 10:24 a.m.
You might get away with a vband slip joint and extra pipe length to an aftermarket exhaust setup.  They work really well and are cheap if you hunt them on amazon etc.
Streetwiseguy MegaDork
11/16/20 11:34 a.m.
You need to connect to the inside pipe.  The outer is just a heat shield.  You need to add a flex joint of some sort somewhere, solid pipe will break pretty quickly.
You need a welder.
11/16/20 11:48 a.m.
This is the time for a cheap ebay header and exhaust. Easy button.
Stefan (Forum Supporter)
Stefan (Forum Supporter) GRM+ Memberand MegaDork
11/16/20 12:01 p.m.
Grab another exhaust manifold and downpipe off car-part.com or eBay.com.
Otherwise, you'll need to cut back that heatshield to get to the inner pipe, then cover it with a new heatshield to avoid heating the oil up too much.
84FSP
84FSP UltraDork
11/16/20 12:49 p.m.
Probably easier to just grab a used / new header and downpipe if you can find one.
11/16/20 12:50 p.m.
Ebay turbo manifold, turbo, injectors, downpipe, raising rate fuel pressure regulator, fuel pump.
saruken
saruken Reader
11/16/20 1:20 p.m.
Thanks everyone for the replies. I'm only seeing 1 header on eBay for my actual engine (1.5L EM-1), but no downpipes. Almost everything is for D Series engines, but mine is a 2nd gen ('80 - '83) Civic.
Car-part.com does list 1 header in my area, but the yard's website is down. I haven't used car-part.com before – Are their recyclers generally willing to ship?
jfryjfry (Forum Supporter)
jfryjfry (Forum Supporter) Dork
11/16/20 4:32 p.m.
Sounds like you're doing the right thing.  But keep in mind:
Buying a welder might make you a welder but doesn't mean you can weld.
11/16/20 5:11 p.m.
Band clamp. Easy.
Or swing by your local exhaust shop. They can build you something.
Curtis73 (Forum Supporter)
11/16/20 6:05 p.m.
New manifold, new header, or simply stop by a muffler shop and have them weld a flange on your existing pipe.
Jz1zhBQEpFoEUxlmZPP1nZQRntzj1RqPkfCvceZiFprhb1Mglxx37xUeB0I11CTg
