Gearheadotaku
Gearheadotaku GRM+ Memberand HalfDork
12/12/09 2:26 p.m.
I'm sure I'll get bashed for this question, but here we go....
Is it possible to remove the front 1/2 shafts from a WRX or standard Imperza and make it RWD? I assume some sort of mod's will need to be made inside the trans. I'm thinking of the 2001-2006 cars, manual trans. I'll then need a LSD for the rear diff, but I'll assume thats available in the aftermarket. No, I'm not planning a drift car.
Toyman01
Toyman01 GRM+ Memberand HalfDork
12/12/09 2:40 p.m.
Probably only once. I don't think you can do it three times...
aussiesmg
aussiesmg SuperDork
12/12/09 2:45 p.m.
My access to GRM shut down for a few also, I may have done this in my response to another thread
BoxheadTim
BoxheadTim GRM+ Memberand Reader
12/12/09 2:50 p.m.
As Toyman01 says, it is doable once. My local tuner suggested doing exactly that to a WRX when I was looking for a track toy as it supposedly improves on-road handling massively.
Unfortunately the place has shut down so I can't get any more info
Brust
Brust Reader
12/12/09 2:59 p.m.
Saker cars Australia has a kit to make the awd trans fwd for mid engined applications, but I have heard of something similar making the trans rwd. Essentially I think you'd want to lock the center diff and you're off. Make it a 4wd trans, remove the front halfshafts, and go. Or wait until a few Toyobaru's end up in junkyards and take their transmissions.
Brust
Brust Reader
12/12/09 2:59 p.m.
sheesh. Its like a pandemic.
Toyman01
12/12/09 3:06 p.m.
^^ The server must have a st st stutter...
NYG95GA
NYG95GA SuperDork
12/12/09 3:10 p.m.
Repost!
unevolved
unevolved Reader
12/12/09 3:16 p.m.
http://www.bremarauto.com/subaru_transaxle_conversion.htm
My mind just blew. Seriously. I've got some many potential projects running through my mind I can't think straight.
Think I could get a bellhousing to adapt a 13B to a EJ20 transmission?
Gearheadotaku
12/12/09 3:36 p.m.
Sorry for the multiple posts. The screen would show "timed out" so I hit post, then "timed out"... It led me to believe that the post hadn't posted, but later posted 3 times...Really, I wasn't trying to post whore!
pres589
pres589 Reader
12/12/09 4:02 p.m.
In reply to unevolved:
This means that a Porsche Boxster with a trashed engine.... could take the drive train from a WRX, right? I mean... RIGHT???
unevolved
unevolved Reader
12/12/09 4:23 p.m.
This means if I could make an adapter plate for a 13B-scooby transmission, I'd have a twin turbo, mid engine, rotary '83 Corolla wagon.
pres589
pres589 Reader
12/12/09 6:41 p.m.
I guess that's cool too.
CLNSC3
CLNSC3 Reader
12/12/09 7:31 p.m.
I believe that you can either do it with one of the kits that is available or you can do the more ghetto method of welding the center diff and removing the front drive axles or something like that! You would probably want to replace the rear end because I hear they do not last long with twice the power being sent to them.
I believe Sport Compact Car had an article about this a few years ago, it may still be in the archives somewhere!
Appleseed Dork
12/12/09 8:37 p.m.
CLNSC3 wrote: I believe Sport Compact Car had an article about this a few years ago, it may still be in the archives somewhere!
Correct. I was thinking the same thing. Maybe Google "drift Subaru" and see if they give any hints to RWD conversion.
Here's a start:
http://www.rocketrally.com/website/index.php?option=com_oscommerce&osMod=index&cPath=40_182_221
MrJoshua
MrJoshua SuperDork
12/12/09 8:38 p.m.
yep, it can be done by welding the center diff. NASIOC has the details.
unevolved
unevolved Reader
12/13/09 9:44 a.m.
pres589 wrote: In reply to unevolved: I guess that's cool too.
Although, come to think of it, an SVX-powered Boxster would be pretty sweet.
digdug18
digdug18 New Reader
12/13/09 10:47 a.m.
yeah, this has all been done before, you just need to do a google search for rwd wrx and you'll find posts on the suby forum. funny thing being that if your going to convert a wrx, you will already have a lsd in the back end...
why not instead of ruining a perfectly good car, start with one that has a blown engine and stuff a v8 rwd in there, lol...
M46S7FqRVZfj224Br3rCq7XLiaiakRZZE4BtiGoZb2pqDeAzBA9pvx3m5AjpRn9O
