slantsix
slantsix New Reader
8/10/19 3:59 p.m.
Is there a known good clutch builder around southwestern pa?  Even eastern ohio would be okay as well
I have a mcleod pressure plate that I want to use for a project but it basically needs the plate cleaned up and ground like a flywheel.  I would just buy a new one but its' very difficult to find any part#'s for performance chrysler/ mopar slant 6 stuff.
Any Ideas?
20190810_135803
20190810_135819
20190810_135834
20190810_135829
20190810_135825
Greg
frenchyd
frenchyd UberDork
8/10/19 6:25 p.m.
In reply to slantsix :
A pressure plate is a pretty basic thing.  You might find one from another make or model will bolt on or can be easily modified to work.
The clutch disk depends on the transmission. If you’re going to use the three speed use a stock one but if you want to switch to another transmission use the disk for that.
w8gzpn0ui4hR75ZXhoP6loY4CLtceAw8oMFUtQqKHtif6Au2b5QbIjcn0qbCYPpA
