One of our top goals for 2017 is to trim down the curb weight of our S197 Mustang. While it will never be a Lotus, there are a few easy paths to less mass in our wide-open CAM ruleset that we can take advantage of without sacrificing much usability.
CAM rules say that the car has to weigh 3200 pounds …
30 lbs down, 370 to go.
How liveable is that poly windshield on the street? (Noise, scratches, glare, etc)
In reply to David S. Wallens:
Cars and coffee edition
Huge thanks for letting us know about these guys. They have windows for the RSX and we need new back glass to replace the old cloudy plastic that's in there. Getting a piece that is curved like stock might make it waterproof-ish which would be helpful. It's now on our list of upgrades.
That's the million-dollar question, isn't it?
Shields has an optional coating (which we employed) that is supposed to the the bee's knees when it comes to abrasion resistance and longevity. Apparently the Disney Monorails use something similar for their windscreens. Just sitting in the car and looking through it, it actually seems more transparent than the glass it replaced.
As for weight, we helped and hurt ourselves with the poly panels. CAM rules state that if you use Lexan panels you carry a 150 lb weight penalty, bringing our new minimum to 3350. Our feeling was we were never going to get to 3200 anyway, but I think we have a pretty realistic path to about 3400 while still being able to retain a/c and a stereo. That 3600lb figure is also with the roll bar, which is an easy 60lbs that we don't need for non-track events.
There is a lot of difference in the 05/06 and then all the others. In STU setup the '06 sat at 3200 even in race prep. I always am amazed at the range of weight on the S197's.
Did you check to see if a Lexan front windscreen was street legal?
For real. My '05 GT 5spd with full options (leather, power, dash trim, etc) weighed 3400 without the jack and spare and 1/4 tank of go-go juice.
kb58
Dork
12/20/16 1:54 p.m.
I used the coated Lexan in Kimini. It works fine if you clean it gently with a micro-weave cloth, but don't think about using wipers on it.
pirate
Reader
12/21/16 3:23 p.m.
There is a product called Plexus (spray can) that is very good for Plexiglass/Lexan/Polycarbonate. Its fairly expensive for a glass type cleaner but works well with a soft towel or microfiber cloth. I would agree that wipers are the kiss of death with or without the anti-scratch coatings. I have been told RainX will put a permanent haze on Lexan/Polycarbonate but do not know that for sure. Would like to find a product similar to RainX if anyone knows about one!
Wow. IMHO, this equals "not livable on the street." This is barely livable for "streetable enough to drive to events."
Wonder where "car wash" falls on the spectrum, and how long a rear window would last...
I highly approve this post
Thank you.
Also, regarding Plexus.
JG can probably remember the story better than I can, but like 20 years ago someone from Plexus bugged us about their product. It's awesome, they said. Fine, we said, we'd try it out.
Wow, that stuff kicked all the butt. Plus it has a pleasant fragrance. Since then, I've always had a can in the garage.
I jave been using Plexus long before it hit the automotive/motorcycle markets. It started out for aircraft windshields and has been great on my Piper Aztecs windows all these years.
