NBS2005
NBS2005 Dork
10/31/08 10:07 a.m.
Pulling into the garage this morning I noticed a puddle under the neon. It's oil. Crank oil is full. I quick look see underneath shows a big oily mess on the underside of the tranny near where it joins the motor. So it would appear to be gear oil.
Looking for suggestions on how to proceed. Is this a known problem spot for Neons? I had peaked under there before and notice it was grimy, but it's a whole lot worse now.
Any help would be appreciated.
Duke Dork
10/31/08 10:33 a.m.
It may well be the main seal, but check the oil pressure sender, too. It's in that neck of the woods (center back side of the block, low) and they are known to fail and spray oil all over.
Headgaskets are usually more of a weep down the back side of the block.
NYG95GA
NYG95GA Dork
10/31/08 10:39 a.m.
I'm with Duke on this one. It's most likely the oil pressure sensor. They're prone to do that. Back of the block, just under the exhaust.
iceracer
iceracer Reader
10/31/08 10:41 a.m.
I developed a transmission oil leak while running at Summit Point. Turns out the pinion shaft in the differential had come adrift and poked a hole in the case.
slantvaliant
slantvaliant New Reader
10/31/08 10:45 a.m.
It's not leaking. It's marking territory
Armitage
Armitage Reader
10/31/08 1:08 p.m.
Most times you can sniff it and see if it's gear oil or regular motor oil and start with that.
walterj
walterj HalfDork
10/31/08 1:12 p.m.
slantvaliant wrote: It's not leaking. It's marking territory
I was going to say "wetting itself like a beat dog" but I thought it might not be all that helpful
curtis73
curtis73 GRM+ Memberand Reader
10/31/08 4:22 p.m.
Its crying at the possibility of GM merging with Chrysler
joshx99
joshx99 New Reader
10/31/08 4:24 p.m.
My Neon does the same thing. The entire bottom is covered in oil, and it leaves a puddle wherever I park it. It stops dripping after it cools down, however.
carguy123
carguy123 HalfDork
10/31/08 9:03 p.m.
and you're surprised, why?
NBS2005
NBS2005 Dork
10/31/08 11:23 p.m.
carguy123 wrote: and you're surprised, why?
No, I'm not surprised at all. The car has been a pain in the a$$ since I got it (it was a gift, so I'm not out for the car). It's only redeeming quality is that it's mildly interesting when the motor spools beyond 6K.
And have you looked under the hood? It's a cram fest in there.
Thanks for the advice.
NYG95GA
NYG95GA Dork
11/1/08 1:07 a.m.
Cram fest? Check this out.
Travis_K
Travis_K Reader
11/2/08 12:37 p.m.
NBS2005 wrote: And have you looked under the hood? It's a cram fest in there.
Have you looked under the hood of almost any other new car? The neon is one of the easier cars that i have worked on to get to everything.
neon4891
neon4891 Dork
11/2/08 10:16 p.m.
easier oil change than a Honda.
NBS2005
NBS2005 Dork
11/2/08 10:22 p.m.
I hate transverse mounts. My 00 Outback has lots of room to work. I know, I'm just bitching.
ignorant
ignorant SuperDork
11/3/08 6:09 a.m.
maybe it's excite to see you?
geW1mO07qBzhT8Ra4jbKNBUHpL35r8WvE5R6Z5ZfjBPcECxuPixF4RCmmlWphpDQ
