I'm trying to pull a stubborn rear main seal on an old Saab 900. There is about 6 inches of space between the seal and the trans, so I can't fit the typical hooked, t-shaped puller in there. In the past, I haven't had troubles getting them out, but this particular seal has a step to it that I haven't encountered and is causing me grief, whereas past seals weren't stepped:
I tried bending a couple paint can openers (per a random forum; didn't work), and I'm about to drill holes for sheet metal screws (also per a forum).
Q: Really, drill into the seal? What about, you know, the engine internals and metal shavings?
