junpower
junpower New Reader
3/15/10 8:16 a.m.
I have a turbo engine lying around my house, if I remove the non turbo original install this motor does it count towards my Budget? If so how much is FMV?
If so I can sell my motor to a friend for $700 but how much is my current motor worth?
Slotting the front rotors and adding hawk pads is this considered budget? I know the machine work is $20 per rotor. Will the brake pads count even tho it is a safety item>?
The car came with aftermarket 17" wheels but I would like to use stock 16" turbo II wheels. Does this count towards my budget? I already have the wheels and tires. The wheels are stock OEM equipment on turbo II rx7's so can I just count the tires?
93celicaGT2
93celicaGT2 SuperDork
3/15/10 8:25 a.m.
Anything you remove, sell it to recoup out of your budget.
If you can get your buddy to pay $700 for your n/a motor, then you just took your budget down to $0. Assign a FMV to your Turbo motor, based off of what they usually go for in that condition.
I have no idea about motor costs for that car, so i can't help you with a number.
Don't both slotting the rotors. There, i just saved you $40!
Adding performance pads DO go against the budget. OEM equivalent do not.
Sell your 17s, use that money to pay FMV for your stock 16s.
DILYSI Dave
DILYSI Dave SuperDork
3/15/10 10:15 a.m.
junpower wrote: I have a turbo engine lying around my house, if I remove the non turbo *original* install this motor does it count towards my Budget? If so how much is FMV? If so I can sell my motor to a friend for $700 but how much is my current motor worth? Slotting the front rotors and adding hawk pads is this considered budget? I know the machine work is $20 per rotor. Will the brake pads count even tho it is a safety item>? The car came with aftermarket 17" wheels but I would like to use stock 16" turbo II wheels. Does this count towards my budget? I already have the wheels and tires. The wheels are stock OEM equipment on turbo II rx7's so can I just count the tires?
FWIW, if you're able to get $700 for a N/A motor, you're gonna have to ding the budget pretty bad for the Turbo motor. If $700 is a realistic number for the original, then I'd expect a grand or more in the budget for the turbo version.
unevolved
unevolved Reader
3/15/10 10:23 a.m.
Friend of mine just sold a T-II engine, trans, and harness for $500 if that helps.
junpower
junpower New Reader
3/15/10 10:10 p.m.
Thank You for your help guys, I did read the rules over 5 times but I do like the opinion of others before i just make up my own mind.
junpower
junpower New Reader
3/16/10 2:09 a.m.
Well I get turbo II motors for about $400-$800 anyways.with everything, harness ECU Long Block trans diff and shaft!
If I get $700 for my motor original motor I can try to find FMV for the turbo II stuff for around $600-$800 that should set me at about $1000 with $1010 left over to spare.
What can i do with $1010 humm.
Car Cost $700 Car Came with RB Dual Primary Road Race Exhaust 17" x 7" Drag Wheels for sale Momo With Quick Release ** $700 car value (MINUS) Wheels for sale $400-$500 Non Turbo Engine Trans Shaft Rear End $500-$700
after selling those parts my budget should start at $0000
Car Budget for both days Engine swap:
S5 89 - 91 Turbo II motor and complete swap + $600-$800 Sock OEM Brake Pads + $000 All Fluids + $000
Drag Day:
2 x Kumho V710 for Drag 225-50-16 on stock wheels = $150
HKS F-Con with FCD = $150
MAN After thinking of everything maybe I should just go non turbo!
Ditch the turbo II swap idea and keep the original motor and sell the wheels and interior to comp back the $700 for car cost and I can just budget tthe whole $2010 to parts, keep things simpler and a bigger budget for mods. I just read other postings of people who are running turbo's on their set ups!?!?! How do you do this and stay under budget!?!
junpower
junpower New Reader
3/16/10 2:47 a.m.
Now I am bouncing Ideas of my 84 GSL-SE rx7
That one cost me $200 dollars.
junpower
junpower New Reader
3/16/10 2:52 a.m.
Wonkothesane wrote: Just for an idea of FMV, I paid $1000 for a freshly-rebuilt TII engine that was ported with all new Atkins Rotary seals and hardened stat gears. I got the transmission for that price too... Which is crazy, I was just about to start ordering parts to rebuild mine and I had about $1400 totaled up :) Edit: I guess I should point out that the post is still available from that sale on rx7club.com, if you need any "proof" that they are around for that price.
I would just use a used motor with good compression.
I found a complete 91 parts for for a pretty penny I won't say just yet but it was under $600 for the complete 1991 RX7 Stock Turbo Parts car Black/Black. I let the cat out of the bag! I am getting a little stingy now and want to keep that set up for my personal project car and possibly just stay non turbo and use the GSL-SE I just picked up.
aussiesmg
aussiesmg SuperDork
3/16/10 3:32 a.m.
Take note you have a couple of conditions on the recoup rule. The maximum total recoup is $1005 and no one item can be recoup claimed for more than you paid for it, profit is nice but not included.
ie: paid $500 for vehicle sold items off it to value $1000, max recoup is $500
ie: selling items to value of $2500 is cool but only $1005 total can be claimed.
6oKCbDLPPEhsbfkPBNyv01O3dPQwRffPok4edCb12qvEdvY0otrMz0WBtCLodFW2
