Taiden
Taiden Reader
4/21/11 6:19 p.m.
Just got a 91 cabriolet with a half-assed AC delete. The lines are cut and that's about it.
I want to remove the lines that go through the firewall. My options are to pull out the entire evaporator (PITA), or just unbolt the lines at the evaporator (easy peasy).
So here's my question. The lines have been open for a year. Is there any issue with leaving the lines open in the cabin? All I know about R12 is all the scary "it's really bad for everything" stuff. I'm all for the easy peasy route if it's safe.
What can you all tell me about this?
Toyman01
Toyman01 GRM+ Memberand SuperDork
4/21/11 6:22 p.m.
If the lines are cut the gas is gone. Don't worry about it.
Donebrokeit
Donebrokeit Reader
4/21/11 6:43 p.m.
R12 is not bad for people , Just cap it off and move on.
Apexcarver
Apexcarver SuperDork
4/21/11 7:01 p.m.
http://www.refrigerants.com/msds/r12.pdf
The MSDS sheet for R12
http://en.wikipedia.org/wiki/Dichlorodifluoromethane the Wiki for R12
its bad for the environment, not bad for you.
It wrecks the E36M3 out of the ozone layer
Osterkraut
Osterkraut SuperDork
4/21/11 7:17 p.m.
R12 is mostly bad for DuPont.
pimpm3
pimpm3 New Reader
4/21/11 7:21 p.m.
The same guy who invented CFC's also invented leaded gasoline.
Apparently he has had the greatest impact on the planet of any single organism...
http://en.wikipedia.org/wiki/Thomas_Midgley,_Jr.
Before he died and they realized the impact of his inventions he was the pimp...
porksboy
porksboy SuperDork
4/21/11 7:50 p.m.
R12 is bad if you combust it, say thru the intake manifold of a running car. It will produce Phosgene, ask me how I know. 6 people sent to the hospital at a shop I worked for. I was off that day and had nothing to do with it. The schooling we were forced to take under order of OSHA was interesting. Phosgene was also used as a chemical weapon during WWI.
Like mentioned above once the lines are open the R12 is gone. The oil from the system on the other hand...
Taiden
Taiden Reader
4/21/11 7:54 p.m.
Phosgene scares the E36 M3 outta me, heard all the horror stories about using chlorinated brake cleaner on a part and then TIG welding it.
What's the deal with the oil in the system?
Rufledt
Rufledt HalfDork
4/21/11 8:02 p.m.
If it was bad, I'd be dead. My van has been leaking R12 for years.
Dr. Hess
Dr. Hess SuperDork
4/21/11 9:04 p.m.
Highly non-reactive. And heavy. Very heavy. So heavy that it sinks to the bottom of your shop and will suffocate you if you are laying under the car because it pushes out the oxygen. And it is so heavy and unreactive that it rises up 100K feet and reacts with ozone. A man got a Nobel prize for that. Then he later said he was all wrong about it, but I think he kept the money. And Dupont kept the money from R134a. And that was the blueprint for Global Warming, the declaring of Carbon Dioxide, the molecule around which Life is based, as a hazardous substance, to be regulated and banned.
So, don't worry about your cut lines.
novaderrik
novaderrik HalfDork
4/21/11 9:49 p.m.
Dr. Hess wrote: Highly non-reactive. And heavy. Very heavy. So heavy that it sinks to the bottom of your shop and will suffocate you if you are laying under the car because it pushes out the oxygen. And it is so heavy and unreactive that it rises up 100K feet and reacts with ozone. A man got a Nobel prize for that. Then he later said he was all wrong about it, but I think he kept the money. And Dupont kept the money from R134a. And that was the blueprint for Global Warming, the declaring of Carbon Dioxide, the molecule around which Life is based, as a hazardous substance, to be regulated and banned. So, don't worry about your cut lines.
but.. but.. but.. tomorrow is earth day.. don't be saying such things...
Rufledt
Rufledt HalfDork
4/22/11 2:01 a.m.
whoa it's earth day tomorrow!??! I gotta fire up the old Econoline and emit some greenhouse gasses to celebrate.
Taiden
Taiden Reader
4/22/11 1:22 p.m.
Removed the lines from the cabin and capped the evaporator lines by wrapping a bolt in electrical tape and lightly hammering it in. I noticed there was some bright green gunk in there. What is that stuff anyway?
Toyman01
4/22/11 1:38 p.m.
Probably dye from a leak test. It mixes with the oil and turns into some nasty stuff. Not nasty dangerous, just nasty don't get it on your hands.
alfadriver
alfadriver SuperDork
4/22/11 1:42 p.m.
On a non-environmental note- I've heard quite a few times that you can use R134 in an R12 system. Not perfect, but it will do the job.
Just in case you wanted to re-install the lines and all.
(there are times and places that cooling is invaluable...)
hCbgDjvxC1Zle8PXBUJpQREulQ3DlY6imeFWYJq6sfMsh5u0qQgJmcPWWFca7kNT
