bravenrace
bravenrace Dork
11/1/10 9:35 a.m.
What's the best way to do it?
hobiercr
hobiercr GRM+ Memberand Reader
11/1/10 10:14 a.m.
Paging Karl!
jrw1621
jrw1621 SuperDork
11/1/10 10:16 a.m.
Swift blow with hammer - window tint gone.
Dr. Hess
Dr. Hess SuperDork
11/1/10 10:21 a.m.
Razor blade.
sachilles
sachilles HalfDork
11/1/10 10:27 a.m.
Had pretty good luck with a very fine air nozzle on the compressor. You might have to scrape your first spot, but after that it comes up very easily.
stuart in mn
stuart in mn SuperDork
11/1/10 11:00 a.m.
Here are several methods: http://www.wikihow.com/Remove-Window-Tint. From what I've heard the ammonia method works the best.
internetautomart
internetautomart SuperDork
11/1/10 11:41 a.m.
first try to peel it off. worked on the back window of the sol. did it on the side window of the alty too, though that one didn't come out as clean.
Fletch1
Fletch1 Reader
11/1/10 12:03 p.m.
I had to do it when I bought that door for my Crx. It was not fun. It was old too which made it harder. I soaked it in Windex and ammonia then used a blower dryer. I used a razor blaze, getting off as much as I could, and kept spraying Windex/ammonia while using the hair dryer. Did I mention is was not fun? It took me 1-2 hours for one door window. Not sure if thats the best way out someone on here posted it so thats what I did.
ansonivan
ansonivan HalfDork
11/1/10 1:00 p.m.
I peel it without any treatment and then remove the adhesive with ammonia based window cleaner spray, letting the spray soak into the glue for a while is best, scrubbing is no good.
Sometimes it peels as a sheet, usually it comes off in bits and strips.
scardeal
scardeal Reader
11/1/10 1:30 p.m.
I used a blow dryer + razor blade. Not too bad.
hobiercr
11/1/10 1:50 p.m.
Karl (from these forums) mentioned that this method was the best. He said to make sure you have plenty of liquid and let it heat up for a good hour or more. Bag removal process
ditchdigger
ditchdigger HalfDork
11/1/10 1:58 p.m.
Professional tint shops use steam
Pretty much just a clothing steamer like this
Works great.
red5_02
red5_02 New Reader
11/1/10 2:00 p.m.
Yup steam works great. Or you can try peeling it off in sheets and using a cleaner to get rid of the left over adhesive.
44Dwarf
44Dwarf Dork
11/1/10 2:02 p.m.
When I worked at MADICO we'd do test plates and put them under UV lights to make sure there was no fading etc. To remove wed peel if possible the edge if someone cut it to close to the test plate size wed cutt lines in the film then spray striaght lemon ammonia on them qucikly cover with saran-wrap (shrink wrap from shipping) and let it sit a few hours peel if needed an the wipe up the goo.
Karl La Follette
Karl La Follette HalfDork
11/1/10 4:39 p.m.
use soapy water , hot sun, black garbage bags to soften 1/2 hr ish direct sun , dollar store amonia spray , scrubbys , razor blades on side windows ..... black bags no real rhyme nor reason just put em on ,, soapy the better sit back drink a beer , test , no good drink another beer , keep soapy . Once film is basically off hit with amonia spray then hit with razor blades ,, don't be cheap 3 4 razor blades per side window .
Before tinting again tape off windows if have felt and rescrape new blade
http://www.tintdude.com/remove.html
Karl La Follette
11/1/10 5:34 p.m.
Datsun1500 wrote: Take the car to local tint shop. Drop it off. Go have fun. Come back, pay $125, and leave. Some things are worth paying for.
$75 florida W//retint $145
JP4AvosHLXLc300UQwFfINfpNAb8UyfAB1rg8Cp17xFlWEpA3eW4TllUZW3kd9l0
