hobiercr
hobiercr GRM+ Memberand SuperDork
8/24/18 10:12 a.m.
I'm trying to help my wife's niece get her first car. She's on a budget and is stepping out on her own for the first time. While she could afford a used car payment, it would still be for a ~$3000 car. Doing some CL searches for her I came a cross a '92 Volvo 240 Wagon in very good shape except for a supposed blown head gasket. Owner found water in the oil and parked it 8 or so months ago (or that is what he says). The chassis has ~230k on it but it is solid with no rust on the body. I haven't inspected it yet so not a sure thing yet. The asking price is $500.
My question, or, what would the hive recommend?
1. I could pull the head, swap a new head gasket on, change the water pump, etc. and see what we get. I'd do a compression check first just to see but would a BHG effect this?
2. I could pull the head and have it fully refreshed at a local shop that specializes in cylinder heads for $375, new HG, WP, etc.
3. Get a used motor from a number of local dismantler for $375 (MANY available at that price locally) and just swap it in.
Robbie
Robbie GRM+ Memberand PowerDork
8/24/18 10:30 a.m.
swap in a used motor. would likely have significantly less than 230k miles.
BHG might affect compression readings, might not. depends where the blow is.
Erich
Erich UberDork
8/24/18 10:35 a.m.
Used motor. But honestly would just do a B230FT if you're going through the effort of putting a new motor in.
Or a V8
unevolved
unevolved SuperDork
8/24/18 10:40 a.m.
Personally, I'd pull the head and have look before buying a new engine.  Those B230s are seriously hard to kill (I've tried).
Streetwiseguy UltimaDork
8/24/18 10:57 a.m.
Yeah, but when you do manage to kill one, its big trouble. Used is the way to go.
If you can see a blown head gasket on a compression test, you can see the antifreeze spraying out the radiator as well.
A turbo swap is several orders of magnitude more difficult than swapping an engine.
Matthew Kennedy
Matthew Kennedy GRM+ Memberand Reader
8/24/18 11:45 a.m.
That's a very fair price for the car, intact head gasket or not.  It's at least worth having a look, and if you buy it, at least pull the head and see how it looks.  There's a good chance that you can go at the head with some scotchbrite, slap a new gasket in, and be good for another 230k miles.
NickD UberDork
8/24/18 12:49 p.m.
Or a V8
You do realize that this is for his wife's niece's first car, correct?
EvanB
EvanB GRM+ Memberand MegaDork
8/24/18 12:50 p.m.
If the head doesn't need machine work you could do the gasket in a day. Engines are cheap though (I have 3 spares in my garage) so i would do that before sending a head to the machine shop. The engine i put in my black 240 was $60 on Craigslist and it would have been done in a weekend if it wasn't for the turbo and manual swap shenanigans.
hobiercr
8/24/18 2:15 p.m.
In reply to EvanB :
Yeah, i'm thinking either way (HG or swap) it could get knocked out in a weeknd.
8/24/18 2:20 p.m.
If it heated badly enough to leak, the head will be the shape of a bannana.
Sometimes the gaskets will crack for no particular reason, but the head would go to a machine shop for a flatness and pressure test before I bolted it back on.
jstein77
jstein77 UltraDork
8/24/18 2:47 p.m.
The other issue with trying to use the old motor is that it's been sitting for 8 months or so with a blown head gasket, which could mean water in the cylinders that whole time.  Corrosion could be a big problem.
Robbie
8/24/18 3:24 p.m.
I've had a HG let go between two cylinders, so they just pushed compression back and forth between them. no external symptoms other than almost no compression in those two holes.
hobiercr
8/24/18 3:56 p.m.
This had water in the oil so yeah, I'm not excited about how the inside of ths block will look. Pictures to come!
spitfirebill
spitfirebill MegaDork
8/24/18 5:31 p.m.
Get an endoscope that connects to your phone and look inside the cylinders.
alfadriver
alfadriver MegaDork
8/24/18 5:46 p.m.
If the value of a properly working 240 Wagon is over $1000, I'm wondering what the issue is here.
I'd replace the motor, and then look into rebuilding the broken one.  But after the replacement, you are less than $900 into a car that should end up to be a pretty good and reliable car for your niece.  And if she does not like it, it seems like an easy car to sell.
Basically, this is a Wheeler Dealer car that can be "sold" to your niece.
Personally, I see no negatives to any choice as long as you get the car.
djsilver
djsilver Reader
8/24/18 7:59 p.m.
We had an '83-ish for 16 years and nearly 200k while the kids were growing up.  Mine was a B23 with early L-jetronic.  My only issues were I had a shoestring tied to the ECU plug to something in the engine bay to keep tension and continuity on the pins.  That, and it had a sort of PCV filter made of corrugated aluminum wound up that would plug up and cause oil leaks.  Clean it out once/year and all was good.  It was still running like a top when I drove it to the junk yard for body rot.  I also learned the importance of good shocks on a brick for a decent ride.
Toyman01
8/24/18 8:10 p.m.
This. I would assume the engine is scrap and plan accordingly.
deCEjP0VAi7Spo5YmptV25RW9hR7Ig0F3CIV5869v62C7pmhWnMsOdQInjMUknc8
