hobiercr
hobiercr GRM+ Memberand HalfDork
12/8/11 9:34 a.m.
So we just got our 94 Celica Lemons racer rebuild back in and a few of the plastic connector sockets have basically just disintegrated from age/heat. Some of these can be found on Rock Auto (alternator connector) but I can't find ones listed for the H20 sensors, fuel injectors, etc. Most of the JY ones I have found are the same brittle condition. Anyone had luck sourcing these?
Also, we've got a pretty good fuel leak behind the motor and I'm suspecting the injector o-rings. Any preferences on replacement injectors? I'm going to replace all 4 while I'm in there. I know I should have done on reassembly but I was not thinking properly...
N Sperlo
N Sperlo SuperDork
12/8/11 10:33 a.m.
You can always pick up some RadioShack plugs and solder them on. Of course, you are no longer plug & play in the case of any swaps in the future..
Just putting it out there.
rotard
rotard Reader
12/8/11 11:28 a.m.
Sounds like you'll have to hard-wire them.
SupraWes
SupraWes Dork
12/8/11 4:38 p.m.
Fuel injector connectors can usually be found on diyautotune.com sensor plugs are usually standard bosch stuff that can be found on cars all over the junkyards.
Teh E36 M3
Teh E36 M3 Dork
12/8/11 6:47 p.m.
phoenixtuning.com has access to most of the toyota connectors brand new. They used to sell them separately, not sure if they still do.
gtae4TwoulC5Gg6YvjZpKIOgUPId58vD7tWemdigIxM8G5OPjO3r1EQ2JiyIx4VD
