10/10/18 4:57 p.m.
Adrian_Thompson
Adrian_Thompson MegaDork
10/10/18 5:06 p.m.
Cross referencing the Mega Millions lotto thread.  This HAS to happen, but unfortunately I doubt that the SCCA would let it.  Time for a new sanctioning body.
SVreX
SVreX MegaDork
10/10/18 5:08 p.m.
Something is really wrong in the universe.
Adrian_Thompson
10/10/18 5:10 p.m.
SVreX said:
Something is really wrong in the universe........in the best possible way
Fixed
Adrian_Thompson
10/10/18 5:34 p.m.
Don't forget Reliant three wheelers are all (front) mid engined.  They aren't as bad as Clarkson would have you believe.  This is a stick one and I bet the bike engine and box are smaller, lighter and thus even better for rear weight distribution
Image result for reliant robin front suspension
Adrian_Thompson
10/10/18 5:41 p.m.
OOOooo  lookie what I found
DSCF1597DSCF1563DSCF1558
Pete Gossett
10/10/18 6:46 p.m.
In reply to Adrian_Thompson :
I don’t have a clue what “proper” front suspension geometry should look like on a trike, but that looks wonky as E36 M3.
Driven5
Driven5 SuperDork
10/10/18 7:43 p.m.
Maybe if you convert it into the poor-man's Delta Wing?  Put two wheels in extremely close proximity to each other up front...And while you're at it, maybe set the motorcycle engine in a 'sidewinder' configuration where the passenger seat usually goes.
freetors
freetors Reader
10/11/18 6:46 a.m.
Man I know the Robin is built to a price point but it looks incredibly crude!
Adrian_Thompson
10/11/18 8:04 a.m.
I even went looking to see what the narrowest R comp tires was for that reason.  I was hoping to find a 145 ish width, but nothing available.  I know that UK racing uses 135 80/15 tyres, but I don't know what compound they are.
buzzboy
buzzboy Reader
10/11/18 8:23 a.m.
There's no lateral locator on that rear axle is there?
Adrian_Thompson
10/11/18 8:56 a.m.
In reply to buzzboy :
Holy cow, you're right.  The other images I can find show leaf springs, but that's certainly a four link trailing arm so it needs either a panhard or watts link.  I don't know if that is a later car or a conversion that's not finished.  Off to search for answers.
Image result for reliant robin restoration
Adrian_Thompson
10/11/18 9:03 a.m.
Ha, I think I've found it.  It's the angle of the picture.  Look at this one taken from a different angle.
Image result for reliant robin chassis
Notice the lower link at about 45deg from the center line.  That's the lateral location.  There's a name for it that I'm forgetting, but it's similar to what the early 50's C type jags did, and that was good enough to win LeMans in 51 and 53
Apexcarver
Apexcarver UltimaDork
10/11/18 9:12 a.m.
https://americanraceronline.com/tires/formula-v-pro-four/
Bias ply, but probably the narrowest stuff out there.
APEowner
APEowner GRM+ Memberand Dork
10/11/18 10:03 a.m.
Hmm.  I'm not convinced that adding power fixes any of the Robin's real problems.
Pete Gossett
10/11/18 10:05 a.m.
If the rear wheels never gain traction they can’t bite & flip it over, right?
_
_ Reader
10/11/18 10:23 a.m.
I can’t believe I am the first one to post this
edit:  shat. It is not in GIF form....
Birthdays
DZyHTiDIATT8RO54gFk35izh8HFIewOy8tXmfvqfP9JrIA4H1hp5ZqHRksELExAg
