fujioko
fujioko New Reader
5/7/13 11:27 a.m.
I have a Harddog rollbar/showbar in my 94 Miata and I'm not sure why I need it.
If I remove it, I'll save some weight and the seat-belts may work better.
Keep or remove?
[URL=http://s62.photobucket.com/user/fujioko/media/adventure/roll_zps05f984a0.jpg.html][/URL]
petegossett
petegossett GRM+ Memberand UberDork
5/7/13 11:35 a.m.
It stiffened the chassis a BUNCH in my '96. There's no way I'd remove mine. Plus it may prevent an SUV from parking on my head someday.
JoeyM
JoeyM GRM+ Memberand MegaDork
5/7/13 11:36 a.m.
Is it tall enough to interfere with the top? If not, forget about it.
5/7/13 11:38 a.m.
That's a "Hard Bar", no rear braces. If you're going to have the hassles of living with a bar, it should be a better one than that.
Either add some rear braces or remove it.
fujioko
fujioko New Reader
5/7/13 11:43 a.m.
The soft top and hard top seem to fit fine. I actually forgot about the roll bar until today when I put the top down.
The car is street driven and has a 63 HP engine. I'm more concerned about getting rear ended than a roll over. ( not sure the roll bar would help much in a roll over.).
What are the concerns about getting rear ended?
Jim
Duke PowerDork
5/7/13 12:15 p.m.
Keith Tanner wrote: That's a "Hard Bar", no rear braces. If you're going to have the hassles of living with a bar, it should be a better one than that. Either add some rear braces or remove it.
This. A single hoop with minimal or no bracing is doing very little for you, either as a stiffener or as rollover protection.
fujioko
fujioko New Reader
5/7/13 12:28 p.m.
Done!
Roll bar is already out and moments away from being listed on CL.
Thanks for the advice!
Jim
Kenny_McCormic
Kenny_McCormic Dork
5/7/13 12:42 p.m.
fujioko wrote: What are the concerns about getting rear ended? Jim
There's a reason the spare tire is in the trunk under the floor in a modern car.
z31maniac
z31maniac PowerDork
5/7/13 12:46 p.m.
A wheel that bends hitting a pot hole is really providing that much crush resistance against 4000+ lb vehicle? ANd typically spares are even smaller/weaker than the standard ones.
I would assume they are under the car for trunk space vs being a crush zone.
fanfoy
fanfoy Reader
5/7/13 1:33 p.m.
A wheel that bends hitting a pot hole is really providing that much crush resistance against 4000+ lb vehicle? ANd typically spares are even smaller/weaker than the standard ones. I would assume they are under the car for trunk space vs being a crush zone.
You actually want it to get crushed to absorb as much energy as possible.
Also, a bent wheel will become useless with a very small amount of deformation usually around the outer or inner edges. As a whole, a steel wheel is very strong at resisting crushing.
So yeah, it's helpful.
uVIiRpj6RmSgLfOwG6j2ekBJIBMiidw7iNiRg8pbRYeWAjiqjgGBD0do4Nc8Umly
