deveous9
deveous9 Reader
10/31/11 3:59 p.m.
So finally got the jetta brake problems solved. It runs like a champ but it has a idle problem. When i start it up it will idle high but when i rev it up it idles down and up. i have a low iddle issue and a high iddle issue. when i say low iddle issue i mean it kinds stumbles beween low and medium low. think i will add a video up soon.
mrwillie
mrwillie Reader
10/31/11 4:33 p.m.
Check for air leaks...look for torn, missing hoses, leaks around injector cups, etc...
Cone_Junky
Cone_Junky HalfDork
10/31/11 5:26 p.m.
mrwillie wrote: Check for air leaks...look for torn, missing hoses, leaks around injector cups, etc...
^^^Most likely culprit(s)^^^^^
Also make sure timing is correct, coolant temp sender is working properly, throttel/idle switch is set correctly.
deveous9
deveous9 Reader
10/31/11 11:08 p.m.
i ruled out any air leak problem. I haven't checked the timing yet mostly because i have never set the timing on a vw. how the heck do you set the timing on a 1991 jetta 2.0 gli? And what do you mean by having the throttle switch set correctly?
Aaeo0bGbQIc0ImhG7mMYFvVWYveiqWaOamFPNoyp9ZduD4GbYFWPt03Tsv28XX6i
