lateapexer
lateapexer New Reader
6/18/10 8:36 a.m.
My 84 RX7 with a 12A has a persistent leak from the top driver's side front of the engine. Its not new and I don't seem to loose much more oil than I burn anyway,but I want to know if it can be fixed without an engine rebuild. Previous owners appear to have tried to seal it with a variety of unknown products so I don't think adding more goop will help. I have some skills and time but I'm a little reluctant to explore a rotary. Any thoughts?
belteshazzar
belteshazzar SuperDork
6/18/10 8:51 a.m.
it ain't comin from the distributor is it?
lateapexer
6/18/10 9:13 a.m.
Nope, it seems to be from the top left front of the housing. Hard to tell though.
1988RedT2
1988RedT2 New Reader
6/18/10 10:26 a.m.
I haven't owned a 12A in years, but the oil pedestal o-rings are notorious on 13B's. They're on the top of the driver's side of the engine.
Toyman01
Toyman01 GRM+ Memberand Dork
6/18/10 12:36 p.m.
Mine pored oil between the front housing and the first rotor housing on the drivers side front when I got it. Removed the A/C compressor and the leak stopped. The A/C belt puts a lot of stress on the front housing apparently and caused the o-rings on mine to leak. Removed the stress and the o-rings resealed. good luck. If you want to keep the A/C try loosening the belt some.
Jensenman
Jensenman SuperDork
6/18/10 2:58 p.m.
Had one that did this as well. That's where the oil passage from the pump to the filer pedestal makes a 90 degree turn, there's an O ring between the front iron and the rotor housing, and they leak. I took a long shot and tried this: hosed it down good several times with brake cleaner and let it dry thoroughly. I then used adhesive black silicone (it has to say 'adhesive' on the tube or this won't work) and coated the area with a thin coat, going about 4" either side of the 'corner' and let that dry thoroughly overnight. I went over it three or four more times, each time letting it dry overnight, then fired it up. No leak.
lateapexer
6/18/10 3:15 p.m.
Sounds like a plan, I'll give it a try. Don't want it too clean, the grundge may be all that keeps any oil in it.
7XsMtMxhmJqnjwTijDIWWBKPgNShcGBfIs7bc5Q3IjlxmA4lFwnJzZ7823LbbGYx
