Matt said:
Great replies - thanks! Ya Frenchy your right, track and style are paramount. i'm only on 1 track and that's a 1.3 mile 9 turn course (see very old pic lol). . i'm only using 3rd and 4th for the whole track, there is a low speed (turns 3-4-5, 40-45mph) left-right-left section and i'm at 3300 in 3rd and it blows the tires off if i squeeze the throttle too much, so i was hoping to move the torque peak up a little bit. one of my buddies says i should be in 2nd in 3-4-5 to get out of the torque but I don’t like revving it that much. There's a 911 that beats me up and watching a video of us both nose to tail through that section was an eye opener - all you hear is the 911 because hes flat and i'm off the gas.
GTXvette id love to build another motor, in fact i want to build a pump gas 18 degree motor. This crate motor i have now is really nice, i got a crush on these fast burn heads lol! ironically I've been hesitant to crack it open and mess with anything because its really a gem and i don’t want to make it worse. This winters project is big tires, a cage and safety stuff because i want to hill climb the car. the headers and cam are a weekend project. maybe i’ll just put 4.11 gears instead of the 3.45?
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2018/08/31/1535722108_gimli-track_mmthumb.jpg)
The best solution is to do the calculation yourself. Do you have any on board shots of the tach, hopefully showing where you are on track?
Start breaking it down, X% at 3500-4000 RPM. Y%@ 4000-5000 Z% @ 5000-6000.
Now predict passing opportunities and give the RPM that happens bonus according to your past history. Don’t bother with those you don’t race with. ( different class or massively superior car/ preparation/equipment )
Now buy, borrow, or rent one of those engine analyzer programs.
Set it up by your specs as they exist. If you don’t know flow numbers for example guess and adjust until the power predicted duplicates your power.
Once you have that entered try the various camshafts ( on computer ) based on published specs
then compare each camshafts performance against where you need power on the track.
Dont be afraid to try a whole variety of camshafts. Including off brands and ones you don’t think suitable. It only takes a few minutes to look them up and enter the specs.
In an hour or two you should have your answer. While you’re at it try all sorts of things. Different length headers, different size intake, rocker arm ratios, compression ratio, fuels, anything and everything.
I actually did some reverse engineering playing video games on different tracks and comparing lap times of similar cars to mine against my lap times. Then punched in the added power to see the gain in reality.
It took me months to do because I’m a computer Luddite. Someone who really knows computers could do it in minutes but I’m not that person so I did it the slow way.
I learned that a lot of the expensive stuff made either minor or no real lap time improvements. I bought that program a long time ago and still use it to decide where to spend my money.
