singlemalt76
singlemalt76 New Reader
8/2/11 9:45 p.m.
I've got a problem. I'm doing a head gasket on a GM 3.4L. The car was sitting for a while and the cylinder that had the leak corroded the plug and it's seized tight. Anyone have any tips?
SVreX
SVreX SuperDork
8/2/11 9:56 p.m.
Copius amounts of PB Blaster. After soaking for a day or two, add copius amounts of PB Blaster. Repeat as necessary.
Taiden
Taiden HalfDork
8/2/11 9:58 p.m.
I agree with what SVreX said but I would use the acetone/atf mix in like a 3:2 ratio
That stuff is scary. It made my rusty parts smoke. And heat up.
singlemalt76
8/2/11 10:15 p.m.
In reply to Taiden:
What do you mix that stuff in? I've tried it before in a little squirt bottle and it didn't work to well. Maybe I didn't have the mix right.
Taiden
Taiden HalfDork
8/2/11 10:20 p.m.
I got a squirt bottle from the hardware store that actually worked really well. I was surprised. I've been mulling over the idea of the glass medicine droppers that you see lots of supplements and stuff in. I've never actually needed a sprayer. A few drops would do the trick. That stuff is seriously scary. The mix is 1:1 but you can adjust it to thin it down even more.
singlemalt76
8/2/11 10:39 p.m.
In reply to Taiden:
Thanks for the tip.
fasted58
fasted58 Dork
8/2/11 10:56 p.m.
keep the acetone/ atf mixed during use, it will separate if left to stand
44Dwarf
44Dwarf Dork
8/3/11 6:54 a.m.
add a ball bearing or two in the bottle to add in keeping it mixed.
pilotbraden
pilotbraden HalfDork
8/3/11 8:39 a.m.
I keep my ATF/acetone combo in an old Seafoam can
singlemalt76
8/5/11 8:26 p.m.
Eureka! I got it out. The A/A combo did the trick. Thanks all.
Taiden
Taiden HalfDork
8/5/11 9:46 p.m.
singlemalt76 wrote: Eureka! I got it out. The A/A combo did the trick. Thanks all.
Was the A/A the missing piece of the puzzle?
That stuff really is scary good. I just use WD-40 these days. It seems to have the most uses.
porksboy
porksboy SuperDork
8/5/11 10:03 p.m.
Can someone enlighten me on the acetone/ ATF trick please?
fasted58
fasted58 Dork
8/5/11 10:20 p.m.
http://grassrootsmotorsports.com/tech-tips/55/
I9vYphzvf0VrK4YekwM3Z8ugUjt3BRSMLIxHn9MkPGpuAVhE3TK4zVBqh7lqqU9G
