1988RedT2
1988RedT2 UltraDork
8/2/12 5:47 p.m.
You absolutely must buy it and add turbo rotary power. Kinda like this:
http://www.youtube.com/watch?v=Ca9b_6AzlKM
Argo1
Argo1 GRM+ Memberand Reader
8/2/12 7:31 p.m.
I know where there is an 8 second Starlet powered by a rotary. Huge rear slicks. It traps 170 with that tiny wheelbase. Scary.
Dr. Hess
Dr. Hess UltimaDork
8/2/12 8:37 p.m.
I have an axle for that in my shed. $25 and you pick it up.
HappyAndy
HappyAndy Dork
8/2/12 9:31 p.m.
Man, I haven't seen a Starlet in the Philly area since the ninties!
singleslammer
singleslammer Reader
8/2/12 9:35 p.m.
In reply to 1988RedT2:
Holy E36 M3!
In reply to Dr. Hess:
I might be taking you up on that. What is this particular axle you speak of? WHEN the starlet axle dies I will probably upgrade to something that isn't made of glass.
singleslammer
8/2/12 9:39 p.m.
Also, the wife has gave her blessing, grudgingly. I have to sell another project, but that is ok. Anyone want a Triumph ST 955i?
I am thinking most likely the lightest weight OHC v6 I can find. I am thinking KL mated to a w58 (I have one already).
EvanB
EvanB GRM+ Memberand UberDork
8/2/12 9:41 p.m.
singleslammer wrote: Anyone want a Triumph ST 955i?
Yes. Same price as the Starlet right?
singleslammer
8/2/12 9:44 p.m.
In reply to EvanB:
Ha, no. It is closer to adding a zero. It is a basket case but it is worth more than $250
Dr. Hess
Dr. Hess UltimaDork
8/3/12 8:37 a.m.
In reply to singleslammer:
The axle I have is from a Starlet. I forget exactly which one off hand. KP51 sounds familiar. I have the chassis plate at home. I pulled it at a junk yard and mistakenly thought it was the same as a Rolla axle. The gearing on those is really, really high. Like 2.8 or something.
singleslammer
8/3/12 8:41 a.m.
Yeah, and they only have like a 5.6" ring gear that has major problems with 100 hp. I am planning more than 100 hp so probably not worth the trip. Thanks though. Anyone know of a decent rear axle that is narrow enough to fit under a starlet? ( I think that WMS to WMS is something like 50")
oldeskewltoy
oldeskewltoy HalfDork
8/3/12 11:46 a.m.
I've seen Corolla axles do the job... the 6.7 version with a soild pinion spacer will hold up to most power apps you'd use in a Starlet. The Legend cars use the center sections, so you might contact a legends axle company and have something made.........
My build uses a Legends center section, with gears made by Richmond Racing.
singleslammer
8/3/12 2:10 p.m.
In reply to oldeskewltoy:
Interesting. Sounds expensive though. For that I think that a ford 7.5 would be cheaper to just have shortened.
singleslammer
8/3/12 2:13 p.m.
failboat wrote: I figured out what these wheels are. Damn they are pricey. Or this. I like the panasports too but they seem pricey too. Found a decent tire from a Chinese manufacturer though. Definately not this.
wheelsmithy
wheelsmithy GRM+ Memberand Reader
8/3/12 5:28 p.m.
C:\Documents and Settings\Owner\My Documents\My Pictures\mystarlet C:\Documents and Settings\Owner\My Documents\My C:\Documents and Settings\Owner\My Documents\My Pictures\mystarlet Hopefully pics came through, this is the let I bought locally for $450. Pretty excited, causing me to abandon a Swift GTi project so that it might make this older, cooler car live...
EvanB
8/3/12 5:30 p.m.
In reply to wheelsmithy:
You'll have to host the pictures on a site like Photobucket to post them here.
photobucket.com
oldeskewltoy
8/3/12 6:10 p.m.
singleslammer wrote: In reply to oldeskewltoy: Interesting. Sounds expensive though. For that I think that a ford 7.5 would be cheaper to just have shortened.
all true... but check mass. the Starlet axle is tiny, and proportional to the little starlet, a Ford 7.5 is a weeeeeeee bit heavier, and might make the car a handfull with so much rear unsprung mass
singleslammer
8/4/12 3:15 p.m.
Well. I did. Link to build thread to follow shortly.
wheelsmithy
8/4/12 3:37 p.m.
Sorry gang, too stupid to live.
wheelsmithy
8/4/12 3:54 p.m.
I'm going to stop wasting space trying to show pics until I can actually do it properly, apologies one and all. Slammer. The '80's toyota space van rearend may be worth a look. I'd guess its too wide, but the pumpkin is offset, so maybe narrow only one side??? It takes toyota truck lockers, and I bought, narrowed, and got a Tru Trac installed for less than a grand for another project. AE86 rearends work, but I understand them to be a bit wide, but workable. 1st gen RX-7 rearends look good to me, but I haven't measured. Get a GSL-SE, and swap the whole drivetrain(bolt pattern matches, and factory LSD)?
singleslammer
8/4/12 5:02 p.m.
Good idea! I will see if I can scrounge one of those puppies up.
singleslammer
8/4/12 5:03 p.m.
Build Thread created.
http://grassrootsmotorsports.com/forum/build-threads-and-project-cars/1981-toyota-starlet-aka-death-star/52888/page1/
MichaelYount
MichaelYount New Reader
8/4/12 6:08 p.m.
Always loved these little Starlets. They're based on the same floorpan as the old TE21/TE27 rear drive Corollas from the 70's. More room in the engine compartment than you might think.....I think a junkyard all-aluminum 4.8L baby LS would be about perfect.
singleslammer
8/4/12 6:14 p.m.
I'm sure it would fit, I have seen a 1uz in there. I would rather go light weight with a 4 or a 6. My friend wants me to bike engine it. I have a couple 1 liter sport Bike motors.
smog7
smog7 Dork
8/5/12 9:35 p.m.
$250!! I need to find a deal like this.
1jpW7kHxCWW1QirgIJz1CcEfVYzyOyw5CtmXaZakNYzlTELYNT0UvdK0skzfLtsW
