Indy-Guy
Indy-Guy SuperDork
8/19/17 9:50 p.m.
Looking at starter specs for a small block chevy, I noticed some have dual hole patterns for mounting, and something about flywheel tooth count.
Question: Are there different diameter (stock-ish) flywheels for manual transmissions on the SBC?
This may help me get the over all height short enough to fit in a TR4 engine bay
Dusterbd13
Dusterbd13 UltimaDork
8/19/17 9:53 p.m.
Yes. But i think its primarily auto vs manual for size.
Streetwiseguy UltimaDork
8/19/17 10:16 p.m.
This is info just dragged out of the back of my brain. There are two diameters of flywheels for the early two piece rear seal block. The starter bolts are not for different diameter flywheels. The early ones had two bolts straight across, and the later ones have the holes offset for better control of the starter location. I think all of the full circle rear seal blocks have the offset bolts. I'm not sure if there are two sizes of flywheel for them- I'd bet there is a car sized one, and a truck sized one.
Maybe race stuff- Here is a terribly expensive, super cool answer:
http://www.speedwaymotors.com/Garage-Sale-Tilton-5-1-2-Inch-Low-Ground-Clearance-Package-with-Belt-Drive,41581.html
Knurled
8/19/17 11:00 p.m.
There's 168 tooth flywheels and 153 tooth flywheels. The straight pattern is for 168, the offset is for 153.
I think...
SkinnyG
SkinnyG SuperDork
8/19/17 11:23 p.m.
I have the offset bolt pattern on my '77 C10, and I'm pretty sure I bought a 168 tooth flex plate for it.
maj75
maj75 HalfDork
8/21/17 7:52 a.m.
10.5" and 11". Your bellhousing may require the 10.5". I played mix and match flywheel/clutch/bellhousing on my '72 Nova 350. It was frustrating but I eventually found the right combo.
BrokenYugo
BrokenYugo MegaDork
8/21/17 8:25 a.m.
Knurled wrote: There's 168 tooth flywheels and 153 tooth flywheels. The straight pattern is for 168, the offset is for 153. I think...
Other way around, 168 is offset. Some of the aftermarket mini starters just have two patterns in a row and always use the 153 tooth holes.
volvoclearinghouse
volvoclearinghouse UltraDork
8/21/17 9:06 a.m.
A SBC needs a flywheel? I'd think there would be enough rotating mass there as is...
Two_Tools_In_a_Tent
Two_Tools_In_a_Tent New Reader
8/21/17 12:39 p.m.
Would anyone know in what year the 153-168 change took place? I have an early 327 small block and can't figure out what flywheel, started, pressure place should be used.
BrokenYugo
BrokenYugo MegaDork
8/21/17 1:14 p.m.
Two_Tools_In_a_Tent wrote: Would anyone know in what year the 153-168 change took place? I have an early 327 small block and can't figure out what flywheel, started, pressure place should be used.
It's an application specific thing, not year. I think some bellhousings don't have room for the bigger one, so watch out for that.
3TEumhC6YFwZvGRU5MJ6ahE7jjEX4NtWDzZzHBStRkOKEEnlHVXbrIpOEQ6mwhpI
