DeadSkunk
DeadSkunk UberDork
10/27/16 2:09 p.m.
I've been offered a 1990 RX7 for cheap ,but the owner says it "kills every bug in a 2 mile radius until it warms up". What's involved it new parts, or whatever to make a rotary stop smoking?
pilotbraden
pilotbraden SuperDork
10/27/16 2:20 p.m.
Does it run well after warm up? If so run the hell out of it and it might clear up. It has worked for me.
Brett_Murphy
Brett_Murphy GRM+ Memberand PowerDork
10/27/16 2:23 p.m.
smoking rotary
some of the seals have gone bad
plan on a rebuild
How much of a rebuild is up to you. It could just be the water seals or oil control rings, but no matter what the smart move is to be taking the engine apart, fixing what is wrong and putting it back together.
DeadSkunk
DeadSkunk UberDork
10/27/16 2:26 p.m.
In reply to pilotbraden:
He says it stops smoking after it warms up, which may have taken awhile as it is his ice racing car.
Driven5
Driven5 Dork
10/27/16 2:26 p.m.
Make a rotary stop smoking?...I didn't know that was even possible.
DeadSkunk
DeadSkunk UberDork
10/27/16 2:27 p.m.
In reply to Brett_Murphy:
Would that be any more , or any less complicated than rebuilding a piston engine? I've rebuilt engines before, just no experience with a rotary.
BoxheadTim
BoxheadTim GRM+ Memberand UltimaDork
10/27/16 2:34 p.m.
It's more different than more complicated - there are a couple of annoying time consuming pieces of work like clearancing the side (oil) seals. There are a few decent videos on Youtube about rebuilding them.
Smoke is usual oil getting in the combustion chambers. Water is possible, but that's rather annoying and can create a bunch of corrosion damage.
Rebuilds get a bit expensive when you need new housings, but you won't know until you tear into the engine.
pilotbraden
10/27/16 2:43 p.m.
In reply to DeadSkunk: Running it hard probably won't fix a race car, I was thinking more like old man car that never got over 4,000 rpm.
John Brown
John Brown GRM+ Memberand MegaDork
10/27/16 3:59 p.m.
I know a way to resolve that
tomtomgt356
tomtomgt356 GRM+ Memberand Reader
10/27/16 4:21 p.m.
Driven5 wrote: Make a rotary stop smoking?...I didn't know that was even possible.
Easy...Turn it off! Now getting them to stop leaking is another story...
patgizz
10/27/16 4:38 p.m.
Run 2 stroke oil in your gas so it smokes all the time?
BoxheadTim
10/27/16 4:50 p.m.
In reply to patgizz:
Properly dosed two-smoke oil won't cause any visible smoke.
84FSP
84FSP Dork
10/28/16 8:29 p.m.
Theres's and awful joke about what to do if your wife starts smoking that seems relevant here. Slow down and use a lubricant.
FBUmLAIJWmLPsZOBQaYQqoFxd80kV3rFXtfDkKO8tIMItEy5cpHUJJbVYJ9xcDBu
